what 1.6 roller rockers and guideplates to get
Old Aug 22, 2005 | 09:38 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Shooting for 450 hp at the motor. Someone suggested awhile ago the Comp 1302 1.6 roller rockers. What do you guys think I should go with? Also guideplates, I need to get them asap so my machinist knows how much to take off my stud bosses on the vortec heads so they will fit right. Please let me kno guys asap.
Old Aug 22, 2005 | 09:57 AM
ede's Avatar
ede
shouldn't matter what rocker you run you'd want to remove the same amount of material from the casting for the screw in studs
Old Aug 22, 2005 | 10:01 AM
Car: 2002 SS
Engine: Ls1
HE needs to know how much to mill down on the stud bosses for the guide plates i'm running, he needs the guideplates to work off of. You get what i'm saying.
what guideplates/rockers should I go with in general for my vortec heads.
Old Aug 22, 2005 | 10:37 AM
Car: 2002 SS
Engine: Ls1
k
Old Aug 22, 2005 | 11:32 AM
ede's Avatar
ede
yeah i think i do, you're saying you have a machinist that doesn't have a clue what he's doing right?and you don't care, you're still going to let him do the work on your heads.
Old Aug 22, 2005 | 11:39 AM
Car: 2002 SS
Engine: Ls1
well I'm 17 so how do you expect me to care or not to care about stuff i'm not an expert on??? answer
Old Aug 22, 2005 | 11:42 AM
Car: 2002 SS
Engine: Ls1
It sounded to make sence to me. Maybe he doesnt want to mill down more then he has to.
Old Aug 23, 2005 | 10:49 AM
Car: 2002 SS
Engine: Ls1
Old Aug 23, 2005 | 11:20 AM
ede's Avatar
ede
you need to find a new machinist, it isn't like working for NASA
Old Aug 23, 2005 | 11:30 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
YOU STILL HAVENT BUILT YOUR MOTOR YET?
We started roughly the same time, and I've been driving my car for three months now. What's your hold-up, dude???
Old Aug 23, 2005 | 03:59 PM
Car: 2002 SS
Engine: Ls1
well lets see token, a z06 rim flew off going 55 and now my car was broken into and about 1500 $ worth of damage and stolen audio.
Old Aug 23, 2005 | 05:32 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Torque your damn lugnuts, man. Sorry that's terrible. At least you're okay. Also, F--- car audio, it's absolutely useless. You might be young and think that you're only cool if you've got trunk-rattling bass, but it really doesn't matter. Also, it's dead weight. Keep that crap outta there
Old Aug 24, 2005 | 06:52 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I'm def with ede. But to answer your question, you could go with just about any rocker. I've got harlan sharps on mine, but I've used Crane Golds, Comps, and Scorpions on customers cars. Guideplates, eh. They're all pretty much the same.
Old Aug 25, 2005 | 10:30 AM
Car: 2002 SS
Engine: Ls1
hmm, would it matter what studs I got how much he would have to mill down, cause I may have heard him wrong.
Old Aug 25, 2005 | 11:21 AM
ede's Avatar
ede
only studs i ever used were ARPs but i'd guess anyone that makes a stud would be very clost to what ARP makes, far as diminsions go. i always give the spec i use for ARPS and no ones came back and said my number is wrong yet. still this is a question a machinist shouldn't have to ask and even if he didn't know he could figure it out.
Old Aug 25, 2005 | 07:18 PM
Engine: LB9/383
find an engine builder, not a machinist.
Old Aug 25, 2005 | 07:24 PM
Car: 2002 SS
Engine: Ls1
alright, off that topic and on to the rockers lol How are these?
SBChevy Pro Magnum Rockers - 3/8 Stud - 1.6 Ratio
I'm not sure If I should get those but they were suggested to me.
Old Aug 25, 2005 | 07:48 PM
Engine: LB9/383
They're ok, but try to go with an aluminum bodied rocker.
Old Aug 25, 2005 | 08:30 PM
Car: 2002 SS
Engine: Ls1
NastyL98_T/A They're ok, but try to go with an aluminum bodied rocker.
are you sure? Those are said to be better then aluminums. Anyone else fimiliar with the pro mags?
I'm lookin at this comp roller rocker if I need another choice at summit CCA-1044-16 it looks pretty good, 300 $ compared to the pro mags 343$ so its cheaper. What do yous think the usual price is to spend on a good roller rocker for a 450 hp engine. 1.6's
Old Aug 26, 2005 | 04:54 AM
ede's Avatar
ede
use steel full roller trunnion rockers, like comp, actually comp is all i'd consider. the steel is lighter and stronger. the aluminum rocker will fail at some point, metallurgical fact you can't get around.
Old Aug 26, 2005 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Since you need to purchase studs and rockers, get the 7/16" studs along with the correct rocker to fit. They are stronger and won't flex as much as the 3/8" stud. Head machining is the same between them.
RBob.
Old Aug 26, 2005 | 10:05 AM
Engine: LB9/383
Guess it's just a matter of preference. I've never seen an aluminum rocker fail. Usually the stud will give first and snap.
Old Aug 26, 2005 | 10:08 AM
ede's Avatar
ede
you must not of seen many rockers, like i said metallurgical fact you can't get around, aluminum fatigues and fails
Old Aug 26, 2005 | 11:48 AM
firebirdjones's Avatar
rockers
Yep they do break, I am not much of a fan of aluminum either. Plus you have all the steel needle bearings riding against an aluminum body, steel against aluminum is usually not a good mix and they eventually wear out, especially if you run alot of spring pressure. I prefer the Crower steel full rollers and the comp cams chrome molly full rollers, they are more expensive but you shouldn't have to worry about them for a long long time. Larry.
Old Aug 26, 2005 | 11:55 PM
Engine: LB9/383
Nope, haven't seen many rockers at all. Man, you guys really know your stuff.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
