Turn Sig. Help
Old Oct 17, 2001 | 05:27 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Turn Sig. Help
Hey guys I have a problem my turn signal is not getting power to the back right side. The front right one will come on but will not blink. What can I check, I used the meter to be sure there is no voltage in the back and there is none.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Oct 17, 2001 | 06:52 PM
ede's Avatar
ede
i'd start probing wires fro the turn signal switch under the searing column looking for one to trip the test light. if you have power out of the switch trace it back and see where it stops at. just a WAG but i'd suspect the switch. make sure fuses are all good.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
