what does H.O. mean?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The cam, intake, exhaust were different from the "non-HO" LG4. The HO engines made 190hp IIRC. There isn't really anything special about them. They weren't TBI cars but instead carb.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IMO, the HO cars, the L69's, were the first kick-*** cars of the 80's--138 mph top end and 'Vette stompers. Along with motor mods, electric fans, and a dual snorkel (at least on the Camaros), they were equipped with 3.73's. Do a search for more info.
JamesC
JamesC
Car: 89 camaro
Engine: 2.8L V6
CAN ANY OF THE ENGINE PARTS FROM THAT MODLE FIT OTHER TBI OR TPI? Also, wouldent the TPI and TBI units have more output as far as HP than the z28 H.O.?
Transmission: 4L80E/4L80E
They could fit, but with even better aftermarket parts available, there's no reason to do it.
Computer carb will make more power with proper modifications (read: aftermarket parts) than TPI or TBI. You might get more low RPM torque with TPI than with carb, but that won't get you far down the track before you're seeing nothing but taillights.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Well, crossfire was TBI, and the LB9 came out in '85, so, you could say that they were available at the same time.
Engine: 383 Carb
Transmission: 4L60
The LU5 didn't have the performance of the L69, and the LB9 couldn't really be called H.O. when the label was already taken by the L69 in 1985 I guess.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
So of the only difference of an LG4 and an L69 is the intake exhaust, and cam. Then since I changed all of those, is my engine still considered an LG4? Or something else?
Not exactly. The differences were in the air cleaner, cam, exhaust, PROM tuning, and carb jetting (recently learned that LG4 & L69 have different primary jetting, as well as the better-known secondary rods & hanger). The AC lines were also routed differently, and the radiator overflow tank was different.
Contrary to popular perception, TPI was never called "HO" by the factory.
Engine: 383 Carb
Transmission: 4L60
Then you'd have an LG4 with upgraded exhaust and cam.
The RPO engine codes only reflect the engine as it was delivered from the factory. As soon as you change anything they're more or less meaningless.
I have a bone-stock LG4, except for the carb, intake, heads, exhaust, cam, lifters, valvesprings, rockers, pistons, rod, crank and block.
JamesC
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
LB9 also went from 9.5:1 in '85-'86 to 9.3:1 in '87-up. Slight dish along with the valve reliefs vs. only valve reliefs.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I'llrocya
Feb 2, 2016 11:43 PM
