Whats it take to put LT1 heads on early block??
Old Aug 25, 2005 | 12:42 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I keep finding LT1 complete engines in a local U pull it here ($100 for the whole motor with accessories, I just don't have the time to yank these though). I have a 1967 327 with a Holley Stealth ram multiport efi on it -- what would it take to use this block and intake with LT1 heads?
Old Aug 25, 2005 | 02:57 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Old Aug 25, 2005 | 03:16 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Nice 2nd gen(correct?) just rebuild the lt1 block
Old Aug 25, 2005 | 03:25 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Modification. They were designed for a reverse coolant flow.
https://www.thirdgen.org/techbb2/sho...on+gen+1+block
Old Aug 25, 2005 | 03:26 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
check the tpi board for the sticky about lt1 heads on an older block.
Old Aug 25, 2005 | 03:27 PM
slayer2000's Avatar
Car: 1990 GTA
damn, vrtc350 beat me to it.
Old Aug 25, 2005 | 05:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is it just me, or does it really make more sense to just install the complete LT1 engine?
Old Aug 25, 2005 | 05:08 PM
five7kid's Avatar
Guess it wasn't just me afterall.
Old Aug 25, 2005 | 05:30 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The LT1 head/intake thing is actually pretty easy. I paid $250 for heads/intake/injectors, and another $180 to modify the heads, $120 to modify intake (could be cheaper at a machine shop I'm sure, I sent away for it), $65 for remote t-stat, and another $30 or so on brass fittings. I didn't count the $85 fuel hoses because those depend on the setup and would be needed more than likely for an LT1 motor anyways.
That's $730 not including the gaskets and other miscellaneous stuff. Not terrible for a good set of heads and a nice intake. That includes all of my shipping expenses as well. I'll eventually send them away for a $1300 port job by Lloyd Eliott. $1300 for porting, $730 for heads/intake, $750 for shortblock, $210 for cam/lifters. That's just under $3000 for 400rwhp+.
Not terrible, but of course this is only engine-related. Doesn't count the transmission or all the money I've dumped into suspension/chassis work either.
Old Aug 28, 2005 | 06:00 PM
Car: 2000 BMW M5
Thanks guys. I may yank a complete LT1 if I have the time. Otherwise I can get the heads for $50/pair. My 30 over 327 is very fresh and would be a shame to pull it for less than a 20 cubic inch gain (plus this is the fast revving small journal 327). Hence the Lt1 head mod idea. I was afraid I remembered the LT1 head mod on an sbc 1 block was way more trouble than it's worth -- I can get a set of new iron aftermarket heads by the time I had the Lt1 head nightmare figured out. Thanks
Old Aug 28, 2005 | 07:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Naw, better to spend all the time and effort to get a set of LT1 heads to work...this way, you don't have to pull the engine out.
Plus, from what I've seen, those wrap-around-over coolant lines look cool.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
camaro71633
Sep 1, 2015 10:24 AM
sreZ28
Aug 14, 2015 07:48 PM
