has anyone run a homemade cold air kit on a Q-jet instead of TPI??
Old Oct 18, 2001 | 08:29 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
if so could you tell me how you did it and also i was wonderin if you might have some pics of it
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Oct 18, 2001 | 08:49 PM
Enkil's Avatar
I don't have any pictures, but the principle's easy enough. You have a carb, so, you have that thing that looks like a garbage can sitting on top of your engine. One one side (two sides if you've got the dual-snorkle model) is a tube running out of the garbage can. That connects to a flexible plastic tube, which connects to that scoop looking thing which is bolted to the front of the engine compartment. Take off the flexible plastic, and use some dryer hose (or any hose you want really.. Dryer hose is just cheap & easy) and attach where the flexible plastic tube used to connect to the air filter housing. Then route the dryer hose to a spot that it can pick up cold air. Voila.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
drathaar907
Aug 6, 2015 04:20 PM
