Cold Air Intake
Old Aug 27, 2005 | 08:30 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Cold Air Intake
Can anyone build me a Cold Air Intake? My car is a 89 Iroc TPI L98 350. I'm a willing to pay any reasonably price meaning not over $100 PLEASE someone come through
Old Aug 27, 2005 | 11:16 PM
DanTheMan_smlk's Avatar
might as well make your own, your price is too cheap.
Old Aug 28, 2005 | 08:32 AM
firebirdjones's Avatar
cold air
L98 Iroc should already have it's own factory cold air setup unless it has been removed and missing. They seem to work decent, it has been gone over many times on here, by simply installing good filters, removing the baffles under the filters, it will free it up and make some improvements. You can even take that a step farther and fab up some duct work behind the fog lights and direct it up to the filters, there is a sticky on this that explains it quite well. I opted not to do this because it will also block some airflow to the radiator. In any case, there are some reasonably quick Irocs on here that are still using the factory air intake setup with the few mods I mentioned above. Hope that helps, Larry.
Old Aug 29, 2005 | 04:14 PM
83 Crossfire TA's Avatar
Um, custom work for much less then the cost of premade stuff... good luck...
Old Aug 29, 2005 | 07:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If you want some PVC pipe glued together then contact me .
Old Aug 30, 2005 | 07:24 AM
Car: '87 Iroc-Z
okay, Who sells premade>?
Old Aug 30, 2005 | 12:13 PM
SLP makes an intake but you will have to relocate your battery if its on the passenger side
Old Aug 31, 2005 | 12:02 PM
and it's going to run you $250...
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
