Buying 1985 Z28 (HELP)
Old Aug 28, 2005 | 06:03 PM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
I am new to the 3 gen F-Bodies i just bought a 1985 Z28 with the 305 TBI 155 hp what mods should i do to up the hp? Im planing in the future to put a new engine in it what engine is the best for that year in Hp and easist to install? Be a really big help to post links where to find the mods for the 305. Thank you very much!
Old Aug 28, 2005 | 09:14 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
intake and exhaust are the best area's to start. there is a great article in this message board about how to make your own cold air intake. i did it and it works great.
also, redo the entire exhaust. get rid of the manifolds and put headers on. make it true duals with flow master mufflers.
this can all be done for under $500 and will add anywhere from 40 to 70 hp.
these should be the first upgrades you do as most other upgrades will require them anyway.
as for anything else, just look around this message board. there is already alot of great info here.
Old Aug 28, 2005 | 09:23 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Most are gonna say just wait till you swap the motor. For now, do upgrades like as mentioned, ones that will be suitable for a bigger cid motor. Exhaust, chassis upgrades, brakes, etc. Then drop that new motor in there No point in modding the 305, if your just gonna pull it anyways.
Old Aug 29, 2005 | 12:16 AM
Jason89RS's Avatar
Back to reality. Your not going to get 40 - 70 from a cold air intake and exhaust work. The bottle neck on these motors is the heads and cam. The exhaust work and intake are a good starting point to build on, but only a starting point. Personally I would start at the suspension and steering. Your car is 20 yrs old and probably needs some work there. Doing the suspension and steering will make for a safer platform when you add a different powerplant with more ponies.
Old Aug 29, 2005 | 12:53 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
While you're right that 40-70hp from exhaust and intake is wet-dream world, You're dead wrong about the location of the "bottle neck". On a stock thirdgen, it is undisputably the exhaust. All of it, from the Manifolds to the tail pipe, is junk.
Old Aug 29, 2005 | 01:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Buying 1985 Z28 (HELP)
Something isn't adding up here. TBI wasn't offered in 1985, TBI HP was 170. Sounds more like you've got the standard LG4 carburated engine.
https://www.thirdgen.org/techbb2/sho...hreadid=261488
Old Aug 30, 2005 | 06:52 PM
Marc 85Z28's Avatar
40-70 HP gain from an intake swap and full exhaust is real world for a decent running LG4. I gained over a full second and 7mph with a dual snorkel, Performer RPM, headers and full 3" exhaust. MANY others have done the same thing...
Old Aug 30, 2005 | 08:25 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I almost believe it.
I've stripped a lot of LG4 cars, and they run that weird flap thing in the exhaust. I'm sure that restricts like nothing else.
40-70hp and a second sounds a bit much. But whatever. I've never modded an LG4. What do I know.
-- Joe
Old Aug 30, 2005 | 08:33 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Re: Buying 1985 Z28 (HELP)
was waiting to see who would catch that
Old Aug 30, 2005 | 11:36 PM
SchwarzCamaroRS's Avatar
yeah, the whole Z28 post with TBI included didnt add up... lol
Old Aug 31, 2005 | 07:10 AM
19kilo's Avatar
Yo
My bad guys juts got the car this morning love it
Old Aug 31, 2005 | 09:07 AM
Engine: LT1, L400
40-70 HP gain from an intake swap and full exhaust....
Yes. But the person who originally said that didn't say intake and exhaust. He said:
Originally posted by mopain ...cold air intake....redo the entire exhaust
The exhaust certainly does make a HUGE difference, and it's an essential mod, but you won't find 70 hp from exhaust and CAI on a stock LG4.
Old Aug 31, 2005 | 01:40 PM
i dont even know if i found 70 hp going from a stock LO3 to an LO5 w/ catback and an open element...
Ducati900ss
Sep 2, 2015 09:05 AM
Thornburg
Aug 27, 2015 11:34 PM
Thornburg
Aug 26, 2015 07:22 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Dquickshift
Aug 12, 2015 06:21 PM
