distributor hold down bolt
Old Aug 29, 2005 | 03:33 PM
demetri's Avatar
Im trying to advance the timing or put it to 0 but I cannot find that stupid bolt to loosen the distributor.
Old Aug 29, 2005 | 04:24 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
It should be on the passenger side, right below the distributor. It can be tough to get at.
Old Aug 29, 2005 | 04:26 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
If you dont have the distributer wrench us a crows foot and extension, works for me every time.
Old Aug 30, 2005 | 06:12 AM
CrazyHawaiian's Avatar
Car: too many ...
Took an extra wrench (forget the mm size) and used a handheld propane torch to bend it to fit (2 guys to do this). Make the bend closer to the box end side. Use the box end around the bolt, open end to hold another wrench you use for leverage. Works great.
Old Aug 30, 2005 | 08:58 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
The bolt should be 9/16.
Old Aug 30, 2005 | 01:46 PM
demetri's Avatar
jesus christ i cant loosen that dam thing. i can get a wrench between the coil and distributor but that thing is hard as a bitch
Old Aug 30, 2005 | 06:08 PM
demetri's Avatar
Hey can you twist the distributor while the car is running?
Old Aug 31, 2005 | 02:10 AM
83 Crossfire TA's Avatar
Go to an auto parts store and get yourself a distributor wrench. I like the ones that break down in the middle and allow you to use a rachet with one half of it for some extra leverage, and they have a bend end with a little step that goes right under the distributor and over the valve cover other stuff next to it...
Old Aug 31, 2005 | 07:16 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
i get to mine with a normal 14mm box wrench. but i had to move my EGR control solenoid to do so (takes about 30 seconds if your slow). it may be different on a TBI car though, never worked on one my self.
they also sell bent necked box wrenches if you cant find the distributor wrench, it would get in there no problem.
sure you can, thats how you adjust the timing.
Old Aug 31, 2005 | 09:35 AM
vrtc350's Avatar
Car: 81 Corvette
You can get a distributor wrench from Sears that has all the necessary bends. It also has a good size handle that gives great leverage. It's only $10
Old Aug 31, 2005 | 10:32 AM
demetri's Avatar
Yea I just got it with a crow. Thanks Guys im gonna adjust it in a lil. So it's unplug the wire first when the cars off. then turn it on, then adjust, then turn it off and plug wire in right?
Old Aug 31, 2005 | 02:50 PM
demetri's Avatar
Ok just adjusted it 5 degrees adavanced from and originally was advanced so much that it was off the grid. its at 5 and idling at about 600RPM. the knock has gone down ALOT.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
86IROC112
Aug 17, 2015 07:57 PM
johanlindgren
Aug 16, 2015 12:16 AM
