Bearing size
Old Aug 30, 2005 | 08:26 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Bearing size
I am reusing a stock crank that has not been resized, just polished. Do I order a set of standard size? .001 is an option, when do you use these?
Old Aug 30, 2005 | 09:49 AM
kevinc's Avatar
Car: 1982 Z28
Whip out your micrometer and measure the mains, then compare against stock size...that'll tell you what oversize bearing you need. It will also tell you if the crank needs more work done on it, if you measure any significant variation.
Same for the rod bearings.
Old Aug 30, 2005 | 10:10 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
What should the two measurements be under to select the .001?
If I measure a journal at 90 degrees and one is over and the other is under, do you take the standard or .001?
Old Aug 30, 2005 | 10:29 AM
kevinc's Avatar
Car: 1982 Z28
You take it back to the machinist for a grind.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
6speedIROC
16
Mar 15, 2023 08:33 PM
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
