crank pully bolt threads screwed up uh o
Old Aug 30, 2005 | 05:28 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
im replacing my timing chain and my crank pully\ harmonic ballancer bolt threads are all spashed up could this mean i somehow stripped out my crank threads a little bit? if so has anybody had this problem before and is it possible to tap new threads in thanks
Old Aug 30, 2005 | 07:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If there aren't enough unstripped threads left, you could drill it out and helicoil it or tap it to the next larger size.
Old Aug 31, 2005 | 05:03 AM
ede's Avatar
ede
my guess is you screwed up the threads when you removed the dampner, try running a tap in the hole and clean them up
ZMWojnar
Brakes
May 12, 2019 10:43 PM
camaro71633
Sep 1, 2015 10:24 AM
Dialed_In
Aug 20, 2015 01:45 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
