Help quick gunna be late for work
Old Oct 21, 2001 | 11:49 AM
DJdude's Avatar
this is the deal i was taking of my AIR system and accidently broke a tiny brittle hose, now my car is vibrating really bad and my oil pressure gauge is all the way up
92rs
new 305TBI cratemotor
K&N
Helix power tower(tbi spacer)
flowmasters
no cat(piped over)
street&performance elec. chip
open element air cleaner
removed hood seals.
"I live life a quarter mile at a time eatin fords and ****tin ricers"
Old Oct 21, 2001 | 11:53 AM
88firebird305's Avatar
Must of been a vac hose of some sort can you glue it back together for a temp fix? or tape it?
Old Oct 21, 2001 | 11:55 AM
DJdude's Avatar
i can only see one end of it i can't find the other the one end i can see comes from the left side of the engine bay and it broke somewhere behind the distributor
[This message has been edited by DJdude (edited October 21, 2001).]
irocbsa's Avatar
If you have a piece of rubber hose that is of similiar diameter you can patch it with that. Just stick one end of the plastic line into the rubber line and do the same on the other side. Instant fix.
bsa
Old Oct 21, 2001 | 12:17 PM
DJdude's Avatar
found it and on my way to work thanks guys
Old Oct 21, 2001 | 12:34 PM
DJdude's Avatar
ok could that vacume tube have something to do with my oil pressure gauge, i'm at work now and my oil pressure was maxed all the way here i didn't have any tubing left at my house so i just taped it and there wasn't much to tape so its still not connected all the way
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals.
Old Oct 21, 2001 | 12:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maxed OP gauge reading = wire disconnected.
The sending unit is right underneath the distributor, so whatever you did back there that broke the vacuum line, you also knocked that wire loose.
ICON Motorsports
Old Oct 21, 2001 | 12:50 PM
DJdude's Avatar
it still moves though my guage needle moves but when i'm not sitting at a light or something then its maxed
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals.
Old Oct 21, 2001 | 06:56 PM
Trent257's Avatar
i ahve the same problem with mine
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
----Comming in a few days----
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco HighFlow catco cat
Jorlain
Aug 24, 2022 05:11 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
happyhapka
Aug 15, 2015 04:42 PM
