AFR hydra rev(lifter problems?)
Old Oct 22, 2001 | 01:55 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I have an AFR hydra rev that I want to use, but my enginer builder says if I have the right springs I wont need it. He also says that they have been known to eat lifters/cams. Anyone had this problem??
Old Oct 22, 2001 | 02:07 PM
Jester's Avatar
I've heard of lots of people using the AFR hydra-rev....but I've never heard of any problems with it. Go ahead and use it.
Old Oct 22, 2001 | 02:24 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Lets see,, what makes him think that a roller lifter that weighs approximately 50 grams more than a non roller can be made to handle 6500+ rpm with 125lbs of valve spring seat pressure?
I have used it on 2 motors and the only thing I don't like is that it is a pain to install and even more a pain to remove. But, it is worth the trouble.
And what could cause it to make the lifter fail? Maybe on a stock roller lifter. They are not designed to have much over stock spring pressure. They are designed for 100k miles of quiet operation.
The springs are about 60 lbs at max pressure and like 30 on the basecircle.
89rs 400sb 4.10 gear and a few aluminum things
[This message has been edited by jcb999 (edited October 23, 2001).]
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
