L69 cam confusion
Old Oct 24, 2001 | 08:03 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
L69 cam confusion
Ok I went to get the XE262H and what I found was XE262H-10. What does the 10 stand for? Is this the cam I need? I searched and found others like CS XE262H-10 and CB.... and XE262H-14. I don't know which to get?
Also is it true that Crow make Comp cams and a similar Crow would be ok?
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
Currently painting
Old Oct 24, 2001 | 08:30 PM
Vader's Avatar
Danger,
The Comp grind number is denoted in the first characters of the number. "XE262H" is the grind number, or the particular pattern that is ground on a cam billet. The suffix is usually for a kit designation, a given lobe timing advance or retard based on the dowel position, distributor gear option, etc.
The "X" is for XTREME Energy, XTREME RPM, XTREME Marine, or XTREME 4 x 4 grinds. The second character can vary whether it is a retrofit roller, hydraulic flat, hydraulic roller, mechanical flat or roller, etc. Dual Energy and Magnum cams usually don't have the letter prefixes.
The three-digit number is generally the advertised duration of the intake lobes, or the effective duration at 0.050" lobe lifts.
The last character or characters vary for lobe finish design, ramp rates, etc.
There are sometimes two-digit numerals following a hyphen at the end of the cam number which usually denotes the LSA. A "-10" should indicate a 110° lobe separation; a "-14" indicates a 114° lobe separation angle, etc.
I would suspect that Crower would hae most of the specs on most every aftermarket cam offered, just like all the major players would. It would surprize me if all manufacturers didn't offer a similar grind for those cams which seem to be particularly effective or popular. Get the specs if you can, especially the area under the curve, acceleration rates, and plotted curve (if you can) and compare on that basis. Then shop for the best deal.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 24, 2001 | 09:19 PM
gruveb's Avatar
Car: 1989 IROC-1
XE-262-10 is what I have, and what a lot of people have used. That's the one I would get.
Old Oct 25, 2001 | 12:04 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Hot Rod just did a test on cam and intake swaps for a 302 Ford, but the results will be valid for most every engine of similar displacement. They found that by stepping DOWN one size from the cams most often recommended for 302s they developed more hp and torque. They also suggested that the more aggressive cams would work just fine when you went up to the 351 engine.
The same rules apply to Chevy small blocks. A 262 cam might be better left for a 350 and a 258 or equivelent be more effective on that 305.
1986 Camaro Sports Coupe
T-tops, variable wiper, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, 3" pipe into Walker Quiet Flow dual exhaust
Edelbrock Performer intake, "Damonized" Q-Jet 4bbl, K&N filter, Crane ignition kit
TH700R4 transmission and Derale cooler
Air conditioning, power windows, power door locks, power brakes, power steering, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Z-28 front and rear sway bars
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
243 horsepower and 326 foot pounds of torque at the flywheel
_ _ _ _ _ __ _ _ _ _ _
Yea verily, and he smote the smog heathens from his small block Chevy, even from the air pump to the converter ...
Todd 1:1
Jorlain
Oct 8, 2015 01:57 AM
Blue419
Sep 10, 2015 01:03 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
