?'s about re-torqueing heads
Old Sep 7, 2005 | 02:36 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
1) do the heads need to be retorqued after so many miles after a rebuild (and would thread sealer be affected?)
2) can they be retorqued with the headers on and if so, how?
seems to me that header tubes are in the way for the outer bolts, but wondered what methods are used to work around that issue. i'm thinking headers need to come off to retorque...
KAM
Old Sep 7, 2005 | 02:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't retorqued a head in years.
Like 22 years.
I wouldn't do it now because now I use Teflon sealant on the threads, and retorquing would disturb that sealant.
It generally isn't required.
Old Sep 7, 2005 | 06:28 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
1.I'm a believer in retourqing aluminum heads,after about 5 heating/cooling cycles.I'm with fiveseven,shouldn't need to with iron heads and quality gaskets.
2.I'm not going to say they can't be,but I'd sure like to see how you'd ever retourque them without dropping the headers back.
Old Sep 8, 2005 | 05:41 AM
Car: '91 Z28
Axle/Gears: 323's
sounds good to me, just wanted to ask to be sure... thanks.
KAM
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
