What Is This Hole For On My Intake??
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hey, i have no idea what this hole is for, any help??
click here for the pic:
http://img380.imageshack.us/img380/4...rts10115ay.jpg
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
mine just has a plug in it but it is for a Temp sending unit or similar. their should be another one on the opposite side of the manifold too.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yes there is a open plug in there. heater hose goes in the opposite one doesnt it?
and so i should just plug this one right. any chance you know what size it is so i can look for a plug?
Transmission: 4L80E/4L80E
Are they on the back runners as well?
I'll have to say that's a return spring mounting that I've never seen before.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Fix that spring, Its an insult to all chevy owners
I drilled a small hole down where the TV cable hooks up on the throttle linkage and ran the spring back to the cable brackets where its supposed to go
I don't like the spring-on-the-bottom-going-to-the-rear set-up, personally. It puts both the spring return force and the throttle application force on the back of the throttle shaft, promoting wear.
Having the return spring on the top and to the front is a much better balanced set-up from a shaft wear standpoint.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah it wouldnt work in the back? the spring makes the throttle come back, if i dont have it on it doesnt come back to where it sits.
but the spring brings it back, where i have it now
84z28350 was talking about the stock arrangement. Instead of hooking the spring to the top of the throttle shaft lever, the factory puts it on the bottom of the throttle shaft lever and runs the spring towards the rear.
So, does your manifold have those ports on the rear coolant runners or not?
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
one more question...if im not mistaken.. there was a hose coming from the brake booster into the intake, is this true?
because on this intake there is no spot for it?
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i run an edelbrock performer 750cfm ill look it up on the net, but if someone knows where, let me know.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
a 1/4" hole i can wrap a hose onto. ill look
you wouldnt happen to know where i could get a diagram do ya.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh only one hole, there is one hole in the middle of the carburetor it has what looks like a pipe plug on the back, with an allen key in the middle of it.
is that it?
is that it?
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
also, the hole i found in the front, i was told to put a 1/2" pipe plug in it, can i use it for the brake booster instead of the back of the carburetor.
if your look at the engine its to the right of the thermostat, there is a pic above.
thanks for the help in advance.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The port on the back of the carb is for the brake booster, it's the same as connecting it to the manifold port.
The port on the front of the manifold is for coolant, not vacuum. If you connect your brake booster to there you'll fill it with antifreeze.
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
your brake booster will work fine hooked to that port. i noticed that you have an old style intake with an oil fill/ vent hole. it is next to the thermostat going all the way through the intake. if i were using that intake i would plug that, also. it is not needed unless you use breatherless valve covers or no pvc.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah i bought a pipe plug for it today.
thats another question.
on the older valve covers i had a pcv valve hooked up
everything from the block up has been replaced including edelbrock elite tall valve covers.
do i need to hook up the pcv valve again??
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
what is NPT port?
i just went to the hardware store asked for a 1/4" hose barb
and its too small going into the edelbrock carburetor
need something a little bigger
NPT = National Pipe Tread. It's a tapered thread not shared with ANY other type of fastener. The NPT measurements (1/4", 3/8", 1/2", etc.) are also not comparable with ANY other type of fastener. A 1/4" NPT thread is HUGE compared to a standard 1/4" bolt thread, for example.
You need a hose barb that is 1/4" NPT thread on one side (to screw into the carb body) and has a 3/8" hose barb on the other end (to attach the vacuum hose going to your brake booster). You might want to take the carb and the brake booster vacuum hose into a hardware store with you so you can be assured the fitting you buy will both fit the carb and take the vacuum hose before you purchase it. Parts get mis-marked sometimes sitting on the shelf.
Also.... do NOT over-tighten the fitting into the carb. Rember the threads are TAPERED and they push outward on the carb body as you tighten it down. This can easily crack the body of the carb if you overdo it. Then you really will be f-ed. Just snug is plenty good. It'll never really feel like it "bottoms" and stops, it'll just get tighter and tighter. You can always tighten it more later if you need to.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its for either a temp sensor or a heater hose fitting. If you don't need it, buy a brass plug and cap it.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok well i took out the little thread thing with the allen key that comes with the carburetor.
i unscrewed it brought it to canadian tire and got a hose barb 3/8's which fits the 1/4" i got does not fit.
Clint
Clint
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh i got a hose barb with 1/4" and it didnt fit i could put it right in the back of the carburetor it just slid in and out.
i went to canadian tire with the original screw that was in the back of the carburetor and matched it up to a 3/8" thread, so i bought that.
Engine: 383 Carb
Transmission: 4L60
Originally posted by 84z28350
Maybe it was just me but i didnt quite catch the 3/8 and 1/4 thing...
Engine: 383 Carb
Transmission: 4L60
From left to right are a 1/4", 3/8" and 1/2" NPT plug. You can see how they're slightly larger than their size suggests.
I tried turning them sideways to try to show how they're tapered, but they keep rolling off the scanner.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i understand what your saying
but i purchased a hosebarb with 1/4" thread and it just fits in the hole i can slide it in and out, its too small.
i bought the 3/8" thread hose barb and it fits perfect
Engine: 383 Carb
Transmission: 4L60
That's a little strange. The 1/4" plug in the picture above was removed from an Edelbrock carb seconds before being scanned.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
not sure its weird, i just went downstairs, and tightened one into the back of the carb, it was 3/8s
thats weird
thats weird
Engine: 383 Carb
Transmission: 4L60
A 1/4" NPT plug is a little over 1/2" O.D, a 3/8" plug is a little under 11/16" O.D. It sounds like they're describing the barb by the hose size instead of the pipe size.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
