question about valve covers and spreaders
Old Sep 8, 2005 | 12:46 PM
Scheister's Avatar
Car: 85 IROC
well i have an oil leak from both valve covers, both at the bottom toward the rear of the engine. originaly i used a cork gasket that cam in a fel-pro kit. today i removed the drivers side cover and noticed that the spreaders are bowed. are they supposed to be bowed? i have also bought a set of the valve cover gaskets that are rubber with the steel in them.
so my questions are:
1) do i need new valve cover spreaders?
2) when you install a new cam, adjust the valves, break it in and dont hear any ticking from the pushrods and rockers do you have to readjust them?
Old Sep 10, 2005 | 03:52 PM
Vader's Avatar
The rocker cover bolt load spreaders should be installed with the crown facing up (bowed downward).
After installing a flat tappet cam and breaking it in, it's always a good idea to re-check lifter preload. You know that the cam lobes had to wear in some in order to polish, and that means a lifter preload change. You're already going to remove the rocker covers and install decent (not cork) gaskets anyway.
Old Sep 10, 2005 | 05:30 PM
Scheister's Avatar
Car: 85 IROC
thanks for the reply, i figured it out yesterday tho
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
