Will these plugs fit my dizzy?
Old Sep 9, 2005 | 01:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I've never bought universal plugs but I need them becuase the stock straight plug boots get burned up on my headers. Anyone use these Accel plugs?
http://store.summitracing.com/defaul...=KeywordSearch
Old Sep 10, 2005 | 04:08 PM
Vader's Avatar
The description says they have "male / HEI ends", so they should plug into the distributor with no problem. The question is if they fit the locator ring that holds the wires together at the distributor.
I particularly like this claim:
"...Ignition wire performance that exceeds SAE specifications."
What specification? For resistance wires? For 1939 DeSotos? For trailer wiring? That's a pretty vague statement, but typical of advertising hype. I noticed no mention of resistance per foot, dielectric strength, ozone resistance, or anything that someone purchasing plug wires might be remotely interested in.
I'd find a set of angle boot Sorenson or Packard wires and forget about the hype. You probably won't get an Accel decal with them, though.
Old Sep 11, 2005 | 09:02 AM
Car: 86 T/A
Engine: HSR 355
Hype? Its $30- the cheapest I found for black right angle spark plugs.
Old Sep 11, 2005 | 11:29 AM
Vader's Avatar
That's probably a good price for what are acceptable quality secondary wires. I just always get a giggle from reading the advertising that apparently has to accompany even the most mundane parts and supplies when these "tuner" supplier places get their hands on them.
Evidently, they can't just sell a universal wire set without some spin. My point was that you could likely get the same (or better) wires at your local parts house for the same or better price, and not have to ship them from a warehouse in Mexico.
NHRA/NASCAR/SAE approved flat washers. These washers meet or exceed SAE specifications. These precision washers are stamped from solid extruded high-tensile steel wire, SPC tested, specially treated, then are cleaned, electopolished, and zinc dichromate plated to produce the finest washer in its price range. These versatile washers are approved for use with bolts, studs, AND nuts. Holes are precision punched to SAE specifications and to tolerances as low as 0.0100000"
Dude. It's a friggin' hardware store variety washer, made by the gazillions in China and India. 2¢ apiece anywhere but Jegs and Summit. It's all in the sales pitch.
junkcltr
Aug 2, 2019 11:12 PM
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Feb 28, 2016 03:33 PM
GouldyGTR
Aug 21, 2015 10:43 PM
92projectcamaro
Aug 6, 2015 01:20 PM
