car sputters
Old Sep 10, 2005 | 11:35 AM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
car sputters
i have a 87 camaro 2.8 v6 when i get on the gas to speed up it sputters a lil and keeps going till i come to a stop and then it is fine i put 93 octane gas in it and then i just yesterday put 89 because of rising gas prices. I am guessing it is the fufel mixture at least i hope that is what it is. what else could be the colprut of this problem. I also just a couple months back put flowmasters on it.
TIA
Old Sep 10, 2005 | 12:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You can mix 87 89 and 93 and You will never know the differance. Your problem is not gas. It could be a variety of tings wrong. Any engine lights? Could be a faulty maf, TPS sensor, or even a miss from a bad plug or wire. Cap or rotor?
Old Sep 10, 2005 | 12:14 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
no engine lights that i can tell where are the plugs located on the 2.8
Old Sep 13, 2005 | 05:04 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
put some fuel injector cleaner in the tank and im going to change the tranny filter and fluid the one thing i just now relized is the tranny sometimes jerks when i get on the gas when changing gears when in overdrive and drive. what could be the problem i have checked the plugs and they are good so what else do i need to check if i can't fix it off to a pro it goes friday morning.
Old Sep 13, 2005 | 09:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Did you try the fuel filter?
Old Sep 13, 2005 | 09:40 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Heres a list of common culprits:
Fuel Filter
MAF Power and Burnoff Relay
Cap/Rotor
EGR Valve
More Serious:
Fuel Pump
Vaccum leak
Injectors, although uncommon, our cars are getting old and they foul out.
Hopes this helps
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
