wrong fuel gauge?
Old Sep 10, 2005 | 10:33 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
wrong fuel gauge?
Whenever I fill my tank I peg the needle about a 1/4" above full. It will take a good 50-70 miles for it to drop down to the full line. I'm usually about 100-130 miles into the tank by the time it reads 3/4's. At that point, the needle starts dropping faster and faster (I usually go about 200 miles on a tank, 230 will make it dry sump around almost any corner).
Could I have the wrong gauge in the car?
Old Sep 10, 2005 | 10:51 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Mine's like that too. I believe you can actually get the fuel pump sender re-calibrated somewhere, but I don't remember where (maybe a DIY job? I don't know..)
Old Sep 11, 2005 | 01:11 AM
JesasaurusRex's Avatar
first off the right gauge is the one thats used with 90ohms, second how did you wire it? 3 wires comin from behind the rear seats, black (fuel tank ground), redish/pink (12volts for fuel pump, so dont use this wire for anything with ur gauge), brown (sending unit)
Old Sep 12, 2005 | 10:09 AM
Gummie's Avatar
Car: 88 GTA
I didn't wire it; the car came this way. I’m assuming it’s wired correctly or I probably wouldn’t be getting any reading at all. I thought that I might have a gauge for a different tank (different scale empty to full)? It’s the only thing I can think of unless the sending unit can somehow become uncelebrated.
Old Sep 12, 2005 | 10:46 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Both my birds did it. The reason you get the sump around a corner is because the lack of baffles, so it seems like you have even less gas. The resistance in the tank due to the shape isn't a linear change so the needle reflects that.
Old Sep 12, 2005 | 04:01 PM
Gummie's Avatar
Car: 88 GTA
I thought it might have something to do with tank design, but I didn't think it would be that drastic. Thanks for the reply firebirdjosh
Old Sep 13, 2005 | 11:30 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Typical crappy GM sending unit. My 84' is the same, empty just below half. Gauge sky-rockets on full. My 86' chev half-ton is the same, on both of it's identical tanks.
Old Sep 13, 2005 | 12:46 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Mines the same way sometimes, If i fill up while i have a half tank or so the needle will go way past full but if i run it till the needle is on E then when i fill it its just a hair above full...
Weird things, also i guess because GM was cheap they never calibrated the sending units for these tanks so 1/2 on the gauge is actually 1/3 of a tank
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
