engine building
Old Oct 27, 2001 | 09:31 PM
90blueRS's Avatar
engine building
OK, sorry i wasnt specific last time.. i will build it for a third gen camaro either an RS or Iroc... i would like to get a high top end as well as quick off the line.. no emmisions to worry bout... (dont think)although it will be a daily driver. gas mileage is not a big deal. i would like to also but a richmond 6 speed in it as well and a posi rear end, i hope this helps.. if anyone has any info on parts and stuff thanks
john
Old Oct 27, 2001 | 09:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Why not just get an LT1 engine and manual tranny from a wrecked 4th gen? You will get the top end power (up to 6200?) and you will get decent "off the line". your fuel mileage will be good, and it will make a great daily driver as far as drivability goes. And you will have your six speed. What are you waiting for?
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Oct 28, 2001 | 01:41 PM
90blueRS's Avatar
will the LT1 fit in a third gen camaro? and if so .. any mods need to be done? and also how does the 6speed hold up? also anything else i can do to add some horses?
JOHN
Old Oct 28, 2001 | 02:11 PM
jag's Avatar
jag
If you go LT-1, be sure to get all the accessories and stuff because they're reverse cooled. If you're wanting a economical performance package, look for a cam with less than 230 degrees intake advance, around .450 valve lift, and about a 112 degree lobe seperation. Also get some good headers and an aftermarket Weiland or Edelbrock intake. I run high 12s with my daily driver SS Monte Carlo with a 305 block. The only big mods were Comp roller rockers, Summit 1103 cam, ported & polished L98 aluminum Corvette heads, Flowtech headers, rebuilt & modified carb, Edelbrock intake, wider tires and Auburn lockup. Camaros hookup better than SSs (I had an 87 IROC-Z). You should easily get to 12s or 13s with these types of mods, and still afford to drive it. My SS gets 13 in the city and 22 on the highway with 3.73 gears!
Old Oct 28, 2001 | 02:35 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I really wouldn't advise an lt1. Sure they made 30 more hp than a 90 tpi but for the much higher cost and complexity through in an L98 with some simple add ons. Plus many lt1 parts are more expensive and have limited head selection.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
