Idel fluctuates ?
Old Sep 12, 2005 | 05:01 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Idle fluctuates ?
1988 formula 350 TPI idle fluctuates when cold.The idel seems normal as soon as the engine warms up.
Could it be a Vac leak????
Old Sep 13, 2005 | 06:59 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
bump
Old Sep 13, 2005 | 07:41 AM
Hoop88Z's Avatar
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
Absolutely. Vacuum leaks are probably the most likely cause. I've got an 88 5.7 that does the same thing, once it warms for a few minutes the car will idle more normally. I have already replaced the CTS thinking that might have done it, but still no. I've chekced for leaks, nothing, cleaned the IAC, now on to the IAT sensor. Good luck, and if you find the problem before I do, lemme know!!
db057
Jan 10, 2020 08:55 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Changa2
Carburetors
Sep 8, 2001 12:30 AM
85 lg4
May 26, 2001 09:58 PM
