which head gaskets?
Old Sep 12, 2005 | 08:49 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
which head gaskets?
I recently bought a fel-pro gasket set, and the head gaskets that came with it fit the motor, but the cylinder holes are smaller than the bores. Which head gaskets should I buy, since I can't return this set. I wish I didn't throw out the old gaskets. I have a somewhat mild 350, with world heads. I got the gasket set at a discount price so it's not that bad. thanks
Old Sep 12, 2005 | 09:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fel-Pro 1003 for cast iron heads, 1010 for aluminum.
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
That's normal for small block gaskets to be larger than the bore. It's so they will also fit bored over 400 blocks as well.
It's kind of a one size fits all thing. Nothing wrong with it.
Those are the ones I use too. The bore on the gasket is normally bigger than the bore on the block for a 350 and much so for a 305.
Old Sep 13, 2005 | 06:24 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
the gasket bores were smaller, which I didn't understand, it was supposed to be for a 350, thanks. I asked my machinist and he told me the same thing.
Old Sep 13, 2005 | 06:29 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I've never seen the gaskets be smaller than the bore. Maybe you got 305 gaskets? If so, then no you shouldn't use them.
Old Sep 13, 2005 | 06:36 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
yeh, i'm going to buy the 1003 gaskets, and throw those in the garbage. thank you ps: There should be more women like you, (driving v8 sport cars)
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
