RTV on 1 piece oil pan gaskets?
Old Sep 9, 2005 | 01:01 PM
llvll4l2c91350's Avatar
do u guys use any RTV on the gaskets at all? if so, do u put it between the block and gasket, or between gasket and pan? and how big of a bead? i have a GM gasket that im bout to put in. thanks.
Old Sep 9, 2005 | 01:40 PM
Russ-So Cal's Avatar
Is it a thick neoprene reusable gasket? If so, you don't need anything. If you do glue it, glue it it the pan.
Old Sep 9, 2005 | 06:21 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
saw pictures of a gasket with some rtv stuff on it where all the rtv came off and started to plug the oil screen not too long ago on here...
it wasn't pretty. might want to be carefull when using it just to make sure you don't put too much on there and be a little sparing.
but other then that think a lot of the 1 piece gaskets don't need the rtv sealer.
might want to wait for more replies though just to make sure
Old Sep 9, 2005 | 11:05 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
you need to put a thin bead where the block, pan and timing cover come together and also the same spot on the back or else you'll have a leak. I also put a thin film all the way around the pan where it meets the block. No leaks.
Old Sep 10, 2005 | 12:18 PM
Damon's Avatar
4 little dabs in the usual 4 "corners" is what I always use. I've never worked up the courage to try it completely bare.
Old Sep 10, 2005 | 06:23 PM
thanx to those who replied. i know there are a lot more people in this place who have done oil pan gaskets so if u could at least TRY to type somethin. i'd like to find out if the majority use it or not. i get back to workin on it on monday.
Old Sep 11, 2005 | 09:14 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I put my 1 piece oil pan gasket on with no sealer...leaked very bad in the front. I heard that you could use them with no sealer but in my case it didn't work. I took the oil pan back off and put sealer on the front where the block, timing chain cover and oil pan come together and its been fine ever since. I'll save my money and buy a regular gasket next time.
Old Sep 11, 2005 | 12:21 PM
Engine: LB9/383
why should everyone reply to your thread if the question has already been answered 5 times?
Old Sep 11, 2005 | 12:44 PM
ede's Avatar
ede
if you use the "special tools" supplied with the gasket there is no need to do anything to keep it in place and there is no need for RTV
Old Sep 11, 2005 | 12:47 PM
Engine: LB9/383
The tools that come with the fel pro gasket make holding the gasket in place real easy, but you still need a dab of RTV at the corners to seal the pan.
Old Sep 11, 2005 | 06:45 PM
ede's Avatar
ede
near as i can figure i've used 6 or 7 on engines i've put together, v6 and SBC, never used anything and never had a leak, or i wasn't sharp enough to spot a leak. it also could be it never had time to develope a leak, i think the v6 only got to 30,000 miles before i totaled the truck it was in, the rest less than that or for other people i have no idea how long or far they lasted.
Old Sep 11, 2005 | 10:08 PM
kirk158's Avatar
Car: 89 RS
Engine: 2.8
I used sealer on my one peice and have had no problems
thin layer on both sides and a little more at the corners
Old Sep 12, 2005 | 10:07 AM
ok sounds good. at the corners most importantly. what about the front or back part of the gasket where that big curve is. do i put anythin there or leave it alone? im talkin about thru the whole length of that section at the front and back. either where it meets the timing cover/rear main seal housing, or on the bottom where it meets the pan.
Old Sep 13, 2005 | 06:42 PM
kirk158's Avatar
Car: 89 RS
Engine: 2.8
yes i put it there also ,when I put mine in and torqued to specs I actually thought to self this gasket may not have needed any sealer at all because it pushed out quite well , but then again for confussion sake I was glad I did and after 700 miles on this chvy 350 3/4 ton which has been tromp on more than a couple times no leaks just checked ;darn proud too............ tho many more mile required for certain reliability
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
