will not start
Old Sep 12, 2005 | 10:04 PM
Grimaldo's Avatar
will not start
Just got my car running again the other day after 3 months. Put 3.42's in it and was loving it for a day. Went cruising shut if off, went to start it back up and it did I took off and it seemed to chug big time then died and has not started back yet. I cleaned the engine earlier that day but if that would of messed something up I dont think it would have waited half a day to do this. I am getting spark because at night my wires are arching like crazy wich I just found out and I am getting fuel. Any other possibilites?
Old Sep 12, 2005 | 10:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Um arching is bad and will make your car not start or run. Try a tune up.
Old Sep 12, 2005 | 10:26 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
Water is bad for the TPS, so I'd check the TPS output.
Seems like more than coincidence that the problem came after washing the engine off.
Old Sep 12, 2005 | 10:34 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Replace those plug wires! Arching would definately make you car act that way.
Old Sep 12, 2005 | 11:16 PM
Russ-So Cal's Avatar
Everytime a plug wire arcs, that spark plug doesn't fire.
Old Sep 13, 2005 | 08:57 AM
Grimaldo's Avatar
Thanks, I did not think that was it though because it was fine all day and I am sure they were arching all day. Plus my old wires did the same thing but my car still ran, ran like crap but it still did.
Old Sep 13, 2005 | 12:26 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
how did you cleen the motor?
Old Sep 13, 2005 | 12:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If it was a pressure washer you might have forced water into places it shouldnt be, like the TPS...
Old Sep 13, 2005 | 09:14 PM
montesa311's Avatar
exactly my thinking
Old Sep 13, 2005 | 10:15 PM
Grimaldo's Avatar
I have a TBI. And today I was trouble shooting and found out its a fuel problem. When I poor gas into the TBI, it will start up. So I checked how much gas is coming out when I try to start it and it's only a drip. I dont know how much usually comes out but it has to be more than a drip. And I just replaced my fuel pump but I got it at Autozone so I do not know right now what to think.
Old Sep 14, 2005 | 08:36 PM
montesa311's Avatar
when the car is in the on position but not started can you hear the fuel pump? it should run for a little then shut off when it comes up to pressure.... also check your fuel filter... and do you have gas in the tank even though the gauge might read it full....
Old Sep 14, 2005 | 10:19 PM
Grimaldo's Avatar
Just filled it up, and yes the pump is priming. When I unhooked the fuel line after the pump and tried starting it gas came out just not sure with out a guage to see if there is enough pressure. Like I said there is only a drip from the injectors and when I poured gas in the TBI it fired right up.
Old Sep 16, 2005 | 11:24 AM
montesa311's Avatar
could be the pressure regulator
Old Sep 16, 2005 | 12:18 PM
Grimaldo's Avatar
Where is that exactly?
Old Sep 19, 2005 | 09:41 PM
Grimaldo's Avatar
Do not ever buy a fuel pump from autozone. Someone told me that the pumps there were made by Walbro and that autozone stamped their name on it to sell it at there stores. I do not think that is the case. I did not even go through a full tank of gas and I have to go in and replace it again. I am buying an oem replacement from the dealer. My first one lasted 150,000 miles so I know they are good.
Old Sep 21, 2005 | 06:40 PM
senatorcbp's Avatar
Car: 89 camaro
Engine: 305 tbi
Transmission: 700 r-4
Grimaldo, I have the same problem. Did you find out what it is? I let my car sit for two years, tried to start it and it just turned over, looked at the TBI and fuel dripped out of the injectors. If I pour fuel into the TBI it runs fine until the fuel is burnt up. Does an expert reading this know what the heck is happening.
Old Oct 3, 2005 | 06:07 PM
Grimaldo's Avatar
It was the fuel pump. Went and bought a ac delco from the dealer and its up and running now.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
