Altering Serpentine Setup
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright I'm going to remove the entire passenger bracket, put sliders on the alternator, change the water pump, and get a shorter belt.
What vehicles came with a long nose standard rotation water pump?
Where can I get a pulley for that water pump with serpentine grooves?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
i don`t think you`re the first but i also want to do this.will somebody please tell me how it can be done as well.PLEASE!
would i have to get a different belt,and what would be used for tension?
can you post a pic on how you got yours to work as far as the alt being adjustable?what did you use.i hate to be a pest but i`m sure other people other than myself can learn from this as well.
Car: 91 Camaro RS
I've been told a slider from a smog pump on a third gen works well, that's what I'm going to try and use. Does the water pump get enough tension from the belt this way? I the length of belt I will need depends on the sliders, but roughly what length will I need?
Car: 91 Camaro RS
I had planned on keeping the alternator on the drivers side, however it could be done like that.
i like how you`ve got yours set DM91RS.do you have anymore pics of it?how did you get the new bracket to move the alt?
did you just cut the power steering bracket in half?because it`s looks like at least half is still stock.
Car: 91 RS
Car: 91 Camaro RS
I measured the belt length to be exactly 50" or 127cm with a measuring tape. What would it be bad if I got the exact size or a 49.5" belt and put it on without making the alternator adjustable? If I got the correct amount of tension would that be a problem? I know that belts stretch over time, but how much? Are belts sized small to account for stretch?
LT1Formula
Oct 8, 2015 08:34 PM
