how much power in 310
Old Nov 5, 2005 | 06:24 PM
  #51
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that cam has 291 advertised duration, so i'd guess it has a high powerband, say 2400-6000RPM? It's an old grind (which we've established right?) so it's probably got a pretty short powerband, and it may start kinda high... but who knows, since it's on a 305 rather then a 350 (typically rated on..)
find out.
Old Nov 6, 2005 | 12:14 AM
  #52
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
yes 291 is adv duration adn it is old grind and i have been getting alot of greff for it but im gona try it and see how it works i more than likely will swap cams later when i do intake and roler tip rockers but this will do to play around with for now and to gt me around evey day till my honda is fixed.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
