How do you move alternator to the air pump location?
Old Oct 30, 2001 | 12:20 AM
JPrevost's Avatar
Car: 91 Red Sled
I have a serpentine system and removed my air pump, what model alternator fits in the air pump location? I know it's the small case design but is it the same model or do I need to use the one that has the mounting holes 180d like on most other models?
Also, does anybody know if you can hookup 2 alternators to one battery or do you need to keep them isolated and run it to another battery?
Old Oct 30, 2001 | 11:27 AM
DM91RS's Avatar
Car: 91 RS
JP
I moved my alt to the A/C location as I deleted the A/C and the pump. Let me know if you have any questions.
Darrell
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Dec 7, 2013 | 11:50 AM
Bluenite's Avatar
Re: How do you move alternator to the air pump location?
Did you have to change anything around?
Old Dec 7, 2013 | 05:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Some idea of what car / engine you own would help
https://www.thirdgen.org/forums/tech...formation.html
Old Dec 7, 2013 | 06:19 PM
Bluenite's Avatar
Sorry bro. I have a 91 camaroz28 with the 350. Wanted to see if the alternator could be moved to where the ac bracket is. I took out the ac unit
Old Dec 7, 2013 | 06:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Read
Old Dec 7, 2013 | 06:37 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The button works
https://www.thirdgen.org/forums/fabr...n-3rd-gen.html
https://www.thirdgen.org/forums/tech...cs-inside.html
https://www.thirdgen.org/forums/tech...r-ac-smog.html
https://www.thirdgen.org/forums/elec...relocated.html
https://www.thirdgen.org/forums/tpi/...-diagrams.html
Old Dec 7, 2013 | 06:59 PM
Bluenite's Avatar
Thank you and ur right the search button does work. That's how I found this thread.
AkDrifted
Aug 17, 2015 07:45 PM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
