Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
alternator relocation 3rd gen
Old Apr 29, 2013 | 08:35 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
Im wanting to clean up the top of the engine a bit in my 92. First thoughts were to get lt1 bracket and run all lt1 acessories with an lt1 alternator relocation kit and also have a/c. Well it would about 1000 or more to do all that with running custom p.s. lines and a/c lines. Now im just thinking of using all stock sero set up but putting the alternator where the smog pump goes and cut the top of the alt. Bracket off just so a littlw more of the engine shows. Anyones done this before or seen pictures?
Old Apr 30, 2013 | 08:56 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: alternator relocation 3rd gen
and then how do you route the belt so that you get good engagement with all the pulleys?
Old May 3, 2013 | 12:57 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I did something similar on my old 305. However, I just pulled the whole passenger side bracket off and picked up a March low mount alt bracket. I used a VERY short belt that wrapped around the bottom of the crank, PS pulley, top of the h2o pulley and around the alt.
Can't even see anything under the intake tube and radiator hose.
Old May 4, 2013 | 07:44 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i wonder if you could go were the smog pump is
Old May 4, 2013 | 08:28 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am doing something similer to iansane.
Check out my build thread for pics very soon.
Old May 4, 2013 | 01:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
IIRC, the bolt spacing is way off and I THINK the depth was different as well. Plus having a huge bracket attached to the side of the motor was, in my opinion, useless. And just to be clear, since my h2o pump was reverse rotation I swapped to a standard version, ultra cheap at any parts store. I don't know what year your car is though.
Old May 7, 2013 | 06:28 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Andrew91GT is running an alternator where the smog pump use to be on a spacer. He's also running a SBF so probably has different alignment on the pulley.
I've gave thought to putting another alternator down there before on the smog pump bracket. 2 1200 RMS amps are too much for stock alternator even overdriven.
Old May 21, 2018 | 09:55 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Attachment 349589
Do you know what the part number is of that alternator bracket?
And it fit your CS130 alternator? what is the clocking of the bolts?
Old May 23, 2018 | 10:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Seems to be this (?) https://www.jegs.com/i/UNKNOWN/335/5...SABEgItXfD_BwE
If that helps any...
Old May 24, 2018 | 12:26 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I don't know if that is the correct one.
CS130 have a different bolt spacing than a 10si or 12si
Plus that one is for a big block
Old May 25, 2018 | 02:28 AM
83 Crossfire TA's Avatar
I pretty much did the same kind of thing, first with the CS130 (killed 2 of them) and then converted over to a CS144 with a much better bracket in the same spot. I also have my PS pump in a similar location on the driver's side:
https://www.thirdgen.org/forums/elec...ons-cs144.html
10 and 12si alternators should have the same dimensions, past that it's up to clocking. The CS144 is larger, I believe there was something like a 17si (something like that) which had similar dimensions.
Old May 25, 2018 | 06:40 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Thanks , that does help alot!
I'm still puzzled that nobody out there is making these brackets for the cs130 or cs144.
I ended up buying a summit brand 10si to get the correct bolt spacing.
Old May 27, 2018 | 04:42 AM
assuming the same clocking, the 10si and cs130 will mount in the same bracket.
Old May 27, 2018 | 07:42 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
No. The cs130 bolt space was 7.25" and the 10si is 6 9/16
Old May 29, 2018 | 05:27 PM
I might have the parts to check it, not sure, but in the thread, I linked the original bracket that I had that I used to mount the CS130 was actually designed for an SI style alternator.
Old May 29, 2018 | 05:48 PM
Yea, no, LB9GTA, what you posted was wrong and my original info is correct, I didn't even have to go and measure alternators, I could just look at my CAD drawings of the parts.
The bottom dark bracket the bracket that you see in my thread mounting the CS130 (go look at the pictures you can see it mounted up). It was sold as a 10/12si bracket and you can see it has a bolt spacing of about 6.561, basically 6-9/16". That outline is an actual 600dpi scan of the original bracket imported into the CAD software.
The bigger bracket is the one that I designed and cut out for the CS144, which I used a bolt spacing of 7.2" (measured from the actual alternator), but 7.25" would have worked fine (you can also see that mounted up in my thread):
In reality, I'm pretty sure that they're actually metric dimensions, but 6-9/16" (for the smaller SI alternators and the CS130 and the CS130D) and 7-1/4" (like I said the dimension I measured/used was actually 7.2", for the bigger CS144, possibly some of the bigger SI alternators) are close enough within the tolerances of the bolt holes that you get using 3/8" bolt holes and I cut a .4" wide slot. There are also new versions of the CS 130 and 144 that have new designations (2something I think) that use the same dimensions)
eightsixseven
Dec 16, 2024 01:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
