My intake manifold bolts are stuck
Old Sep 16, 2005 | 11:22 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I tried to remove a few and I broke my craftsman T-40 bit without even making them budge. There is no way returning it 100+ times will help. What do I even do? They are STUCK. I'm trying to get the heads and manifold out so I can scrap the block.
Old Sep 16, 2005 | 11:42 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I used an air hammer with a chisel bit to first, cut a slot in the bolt head, then lean the air hammer over striking the bolt in a way to turn it. Had them all out in abt 5 mins and they were all stuck.
Had to buy new bolts, but that's ok since I wanted to get rid of that TORX crap anyway.
I did this on an eng stand. Not sure if there would be room for this technique with eng installed.
Old Sep 16, 2005 | 11:55 PM
Scheister's Avatar
Car: 85 IROC
i had 2 stick when i removed my manifold. first one i got out with just a lil heat. second one i took a dremel to and cut the head off of, then i replaced them all with hex head bolts
Old Sep 17, 2005 | 12:24 AM
Car: 86 T/A
Engine: HSR 355
Well Im scrapping the block so dremeling the torx heads off shouldn't be a big deal then. Do the bolts go into the heads? If so then I really need them out.
Old Sep 17, 2005 | 01:06 AM
Scheister's Avatar
Car: 85 IROC
well if you dremel the head off, once you remove the intake you will have enough of a stub to put a stud puller on it and remove it
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
