Would this be a good setup?
Old Sep 17, 2005 | 01:56 PM
82Camaro355's Avatar
Car: 1982 Camaro Sport Coupe
Engine: Modded Carbed 355
Transmission: TH350
I am wondering if this would be a good setup for street and some days at the track. Also, if anyone could tell me about how much horsepower I would be making I would be really thankful. I am going to be running this on a 355SBC. I am also just looking for bolt on stuff, seeing as I don't have access to any fabircation tools. If you have any suggestions, please let me know.
Hooker Super Comp Shortie Headers
Flowmaster American Thunder 2.5 Dual Outlet Exhaust System
Vortech Cast Iron Heads
Summit Cam 234*/234* .488/.488
Valve Grind Gasket Set
Edelbrock Perfromer RPM Vortech w/ Square-bore 4BBL Intake
B&M Megashifter
Edelbrock 14" Round Air Cleaner w/ 3" K&N Filter
Edelbrock Perfromer Series 600 CFM Electric Choke Carb
Moroso Centerbolt Valve Covers
Old Sep 17, 2005 | 08:37 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I like everything I see except the cam.Not that it's a bad grind,but name brand manufacturors have much better,cutting edge technology built in their cams.There's a reason Summit cam kits are cheap.
My recomendation would be a Comp Cams extreme energy,If it were mine I'd go with the XE274.
Old Sep 17, 2005 | 08:52 PM
slapi01's Avatar
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
just be careful on the lift of the cam with using the vortec heads. depending on which ones you get you can run into issues if i'm correct. scoggin dickeys have upgraded vortec heads to handle more lift just to let you know.
Old Sep 17, 2005 | 09:47 PM
Transmission: TH350
I dont plan on leaving the Vortechs stock, so it should be able to handle a cam with a higher lift. And for the cam, that was the only one I could find that fit into my price range. How much is the Comp Cam one, is it worth the extra money?
Old Sep 17, 2005 | 10:02 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
only if you want the extra horsepower. They usually run around $176 for the cam & lifters through summit. Well worth the extra couple $$!!
Old Sep 17, 2005 | 10:08 PM
Transmission: TH350
Oh well, that will fit into my budget. Thanks for the suggestion. Does anyone know how much power this would be making?
Old Sep 17, 2005 | 10:14 PM
Lo-tec's Avatar
enough to make grandpa put on his depends before you take him for a ride!!
Seriously, a solid mid 13 second car. Easy 330-350hp.
Old Sep 17, 2005 | 10:40 PM
Transmission: TH350
Do you have any suggestions so I can get 400HP without nitrous? I have about $200 extra so anything within that?
Old Sep 17, 2005 | 11:15 PM
Irockz's Avatar
Honestly,no.$200 is not chump change,don't get me wrong.But it's also not going to buy a whole lot in the way of added power in your case.Why not go ahead and add a small hit of NOS?
Old Sep 18, 2005 | 02:05 PM
Transmission: TH350
Are there any parts that I could replace any of the ones mentioned above that wouldn't cost me over $200-300 bucks.
Old Sep 18, 2005 | 03:22 PM
brutalform's Avatar
[B]
Replace the Flowmaster with a Dynomax Ultra Flow muffler. Unless you REALLY like the Flowmaster sound, the Dynomax will outflow it.
Old Sep 18, 2005 | 05:59 PM
Lo-tec's Avatar
Be sure and get upgraded vortech heads with better springs for over .500 lift. Summit and scoggin dickey sell them already modified. That might be your extra $200 if you were planning on getting stock ones.
Old Sep 18, 2005 | 08:55 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
some 1.6 rockers?
Old Sep 18, 2005 | 09:17 PM
Transmission: TH350
I was planning on getting the stock Vortechs and modding them myself. I plan to port and polish them, new everything basically.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
squiggy2
Aug 9, 2015 09:30 PM
