Screw leak on Valve Cover
Old Sep 17, 2005 | 03:59 PM
Farfire70's Avatar
I put in a new quart of oil today to compensate for burned oil. After that i went for a drive and when I got back home I looked at the engine and noticed that oil had leaked out on my valve cover from the bolt second from the front. I checked the other bolts on both valve covers and found no other oil but this one had fresh oil and the remains of previous oil on it. How would I take care of this to stop the leak? This may be an easy fix but I've never take off the valve covers and don't really want to do going something that would end up putting gunk into the oil and possibly screwing up the valves...
Old Sep 17, 2005 | 04:03 PM
NEEDforSPEED's Avatar
just take out the screw and whip it off and try to clean the hole it goes into, and thorw some RTV of the threads and tighten it down to specs, why your at it check the rest....
Old Sep 17, 2005 | 04:04 PM
and if there center bolt style is a washer missing? on the top
Old Sep 17, 2005 | 04:06 PM
Farfire70's Avatar
What do you mean by center colt style? I didn't see a washer in it or the others but i'll double check.
Old Sep 17, 2005 | 05:08 PM
the bolts.... go thorw the covers
Old Sep 17, 2005 | 11:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
There really shouldnt be much, if any leakage from the screws unless the return passages are blocked in the heads, or the support has broken away from the cover and allowed oil to splash on the underside of the bolt. I dont have any sealant or copper washers on my cheap mr gasket VC bolts and theres also some wire looms bolted to the covers and Ive never had any leaks thus far.
Check to make sure the passages at the rear of the heads are clear and if they look ok and the VCs are ok then just use some new soft copper washers.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
