cam gears???
Old Sep 18, 2005 | 06:18 AM
IROCNO2's Avatar
Car: 1986 Iroc Z
Engine: 5.7
cam gears???
Other than the cool winding noise you get from installation, what is the major benifits and downfalls of installing cam gears??
Old Sep 18, 2005 | 10:25 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Pros...
No chain stretch.
No chain break.
No chain slack.
Dead accurate valve timing through entire RPM range regardless if your on the throttle or not.
Cons...
Noise.
I've heard *don't have any direct experience* that the vibrations carried over from the crank to the cam can cause premature lifter/lobe wear, but could be an old wive's tale.
Old Sep 18, 2005 | 10:26 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Another con:
you're out the decently hefty price for the gear set whereas a chain would be more than likely sufficient.
Old Sep 18, 2005 | 10:31 AM
AJ_92RS's Avatar
Yea. I was gonna mention that, but a "good" chain and a "cheap" gear set are pretty close in price.
But if you're comparing "good" to "good" then
Expect to spend 3-4 times as much.
Old Sep 18, 2005 | 12:47 PM
trkklr77's Avatar
gears are way more $25 for a dr chain, at least $125 for the cheap gears.
i have the dynagear drive set, very very whiny.
you can get most in both loud and quit sets, these didnt say when i got them. you can also find straight cut [90%] or helicut.
i wouldnt buy another set , but these should last 10 years anyway.
one thing i have been told is that they can screw with the knock sensor. i have notice at very low idles [500 rpm+/-] that you can hear a grumble from the gears.
i am doing a tpi swap and am not sure whats going to happen. i dont want to swap them out.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
