Multi-question post. Tire, seats, fenders and speedometers.
Old Sep 19, 2005 | 01:11 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
I wasn't sure where to put this as it contains interior, body, electronic and tire questions. I searched on most of these and couldn't find exact answers to my specific questions. If there's some post I missed covering one or more, you're welcome to smack me
The first is this. I was at the junkyard today and saw what appeared to be either a highly optioned Trans Am or a GTA. I couldn't tell as it was missing nearly everything identifiable. Missing bumpers, fenders, rpo sticker, etc. It was bright yellow, stock color or not, I dunno. Grey interior. It was at least 1990 or older. Anyway...
It has a 140mph speedo. I didn't check the tach. I know in 91-92 they used a different setup to send information to the speedo. Would this speedo be a bolt in in a 91 Trans Am and read correctly, or is it not worth my time and I should look for a 91-92 speedo. If it has a better tach(I read a post stating something about an 8k tach, unless it was aftermarket) would that be bolt in as well?
Next, if the above is good news for me... The front clear cover was cracked. Is that replaceable? I've never had one off so I'm a good bit in the dark about these things.
Now onto the seats. It has power seats. The seats look like garbage and are grey. I know next to notihng about power seats, however, in searching I've at least found that they would be a direct bolt in, with the possibility of the power cable being in my car already. If not, i'd just have swiped that one or gotten a new one. Anyway...
Since the seats themselves are garbage, is the rail and controls, etc, removable from the seat and able to be bolted onto my existing non power seats?
Next up... My original spare was an inflateable, 195/75/15. It's time has passed. I got a VERY temporary mini spare which is now getting tossed in storage, but. The replacement I just got is a 195/75/14, inflateable. It looked near the same as my original and I neglected to check the size before I got it out of the junk car. Will this tire be ok? Better than the mini already blown up junk tire I already had? Ok with positraction since it's not that little junk tire?
Finally, one last question... I know that the fenders have had changes over the years. I need a new passenger fender. Which years are direct, exact replacements for a 91 TA fender? Also, would that include ALL model fenders? Meaning... Can I use a fender from any base/formula/TA/GTA model of that year without modifications such as adding bolt holes, removing or modifying brackets, etc?
Old Sep 19, 2005 | 01:24 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
the guages i dont know
the seats i think the tracks are able to be put on none power seats
i spare tire should never be put on the rear unless it is the same size as the other tire. ok to get home with an open rear and a smaller tire but on posi you will kill you clutches. what is wronge with your stock one. you can get new tires for it (almost positive).
i think you need a fender off of a 91 92. the 85 - 90 are different.
this is all there in the board but sometimes it is hard to get what you want out of the search function. hope this helps.
Old Sep 19, 2005 | 01:38 AM
Elthesh's Avatar
Yeah, I found a lot of info, but the majority was like, say.. Swapping 4th gen seats in, ability to use the 3rd gen rail on a 4th gen, wiring questions, but nothing specifically about putting the rail and controls on a nonpowered seat. But... I am sure it is there somewhere, buried. But prolly under a completely nonrelated topic. Like... Look at my new radio! and then it goes into power seats, lol.
I figured as much on the fenders.
As for the stock spare, well, it's worn out, badly, and I mean "Man, that wouldn't be safe on Barbie's plastic Vette" unsafe. If you can get replacements, any idea where? Noone seems to have a clue that I've asked. Tire shops, dealers, etc. and do you mean the tire itself or tire and rim? The rim is fine, but definately needs a new inflateable tire. I'd LOVE to find a place that has or can get and install a new inflateable on my existing rim.
Old Sep 19, 2005 | 01:48 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
they have to make them are car isnt the only cars that came with an inflatable spare. i know 300z came with them. ill ask my friend the next time i see him.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
zayne0
Aug 24, 2015 07:22 PM
