Need help with rear hatch!
Old Oct 31, 2001 | 07:42 AM
steel1212's Avatar
I have an 87 Camaro SC here iss my problem.I turned key and opend rear hatch now I cant get it to shut.The part that pulls the hatch closed is like stuck in the down position so it wont shut.There is the sound like a motor is running and wont shut off. I disconnected the battery and connected it back thinking this might help but no luck.Still have the motor sound. Pulled out [LID-fuse] that stopped motor sound.Any help to fix this please!
THANKS
Old Oct 31, 2001 | 09:12 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Usually what you can do is take the back trim panel off (its like 3 phillips head screws and then some of those thumb retaining screws). With the cover off, disconnect the motor harness, and adjust the mechanism so that it is all the way up. With that done, reconnect everything and then close the latch.
A lot of the time the mechanism will simply get out of alignment (from slamming too hard or if you try to close it with something blocking it). If it gets out of adjustment the motor will keep running until it burns out.
0-0Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Oct 31, 2001 | 09:35 AM
Desert86Roc's Avatar
It will shut....just slam it down hard enough to compress the rubber. I had this happen once after my car was hit. The auto pulldown was broken, and would not come back up...so for a few weeks I had to really slam down the hatch to get it to catch. A lot easier than trying to dissasemble everything until you need to.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Oct 31, 2001 | 10:48 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What has happened to me in the past is the motor gets pulled down. Look down into the slot and there should be a switch of some kind of switch that will raise the motor back up.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 31, 2001 | 01:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Same here... all it takes is a screwdriver, you'll find the lever. Hold the switch down enough for the hatch to pull itself all the way down and "click off", then remove the screwdriver, and the hatch will raise up again.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 31, 2001 | 11:10 PM
89IROC5.7's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: A4
I know its been said twice, but for the love of *** try hitting that switch with a screwdriver first. It is often an easy fix for this. A couple years ago I didn't know about this yet and bought a $400 motor I didn't need from the dealer.
Old Oct 31, 2001 | 11:13 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I second that! just hit the lever thats in there and the motor will come back up... dont go takin it apart as you dont need to!
92' White Trans Am Convertible, 305 TPI, 5 spd. 2:73's, Edelbrock TES, Accell 8.8's, Hypertech Stage II, TPIS Air Foil, Ported Plenum, K&N TB Cone Filter, AFPR, & A Little Bit Of Attitude!
-Best ET: 14.944 @ 93.11
88 Gunmetal GTA Hardtop... Project In The Works!
"GUYS, WE NEED TO FIND A MUSTANG TO RACE... THERES ONE! HOLY SH*T SHES HOT! SHES NOT GONNA GO... NAH... HOLY SH*T SHES GOIN!"
Old Oct 31, 2001 | 11:35 PM
Car: 99 Formula
Axle/Gears: 342
Wish I had seen this board when I first got my car and ran into this problem. Maybe I wouldn't have been riding around and gone over a bump and have the hatch fly up, talk about embarrasing. I even tied an extension cord from the hatch to a rod on the back seat to keep it from bouncing. Then one day just by fiddling with the motor I ran across that switch and wow it worked.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Nov 1, 2001 | 07:52 AM
steel1212's Avatar
Thanks for the help I will look for that switch this weekend. ( as soon as I get off these long a$$ 12hr work shifts)
STEEL1212
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
