Is It Ok To Run Without Exhaust?
Old Sep 20, 2005 | 06:02 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i have the motor almost complete, with shorty headers, they end equal length with the bottom of the control arm.
my question is, is it ok to run the motor without the exhaust hooked up to it for a little while, until i get some new bolts and gaskets for them.
Old Sep 20, 2005 | 06:12 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I wouldnt do it with the shorties, the heat from the exhaust might do some damage plus you might shoot some small flames out of them and that wouldnt be good either under the hood.
Old Sep 20, 2005 | 06:13 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
It shouldn't hurt the engine, but it may hurt your relations with the neighbors, not to mention the first local authority figure you happen to pass by......Better to bolt it up and have it a little noisy.
Old Sep 20, 2005 | 06:20 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Its not going to hurt anything.
Old Sep 20, 2005 | 06:28 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
nono i dont have plan on leaving my hard, and the header outlets are pointing toward the ground.
i just want to start it up to make sure the engine fires up alright, i wont be able to put on the exhaust til next week, and i just wanted to fire it up see how it sounds.
Old Sep 20, 2005 | 06:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
As for the engine part of it, no it wont hurt the engine. But as far as your ears go, youd better get a set of earplugs it will be pretty loud.
If you plan on runnin without anything on the heads i wouldnt reccomend it is your going to burn or blacken everything under the hood.
Old Sep 20, 2005 | 06:35 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i stated above headers will be bolted to the motor, just the exhaust wont be bolted to the headers...
Old Sep 20, 2005 | 06:48 PM
meridius's Avatar
people run open headers all the tims but most of the time they are longtubes. It wont hurt the engine to do it but like I said Id be more worried about the heat coming out of them being so close to your firewall. I would also be afraid of stuff catching on fire from the flames that will more than likely be coming out of the headers.
Old Sep 20, 2005 | 07:03 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah yer right, i plan on changing exhaust actually, and i wanted to run the motor in between changes to see if there are any ticks or knocks any leaks.
Old Sep 20, 2005 | 07:05 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
IMO, if you haven't started the engine up before, like if it's new or just rebuilt, I'd bolt the exhuast up and deal with the leak. This way here if the engine has a funny noise, you can hear it over the exhuast. Other than that. No damage can be done.
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
