Air Flow Research---Experiences?
Old Nov 1, 2001 | 06:49 PM
gruveb's Avatar
Car: 1989 IROC-1
http://www.airflowresearch.com/chevy_dyno.htm
I am interested in perhaps building up a 400. Scroll down the page...look at all of the different combos they have there.
I was struck by the 550 hp/540 torque 406...
Any thoughts on this combo?
They claim that "Ceralli Competition Engines" offers the package, but I can't seem to find them on the web anywhere.
http://www.gruveb.com/z28
Old Nov 1, 2001 | 07:27 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think its a little optimistic. Just like AFRs other press releases.
I have a 400 with 10.8 to 1, a set of Brodix Track 1s (that flow almost as well as the AFRs) and a custom hydroller (with more lift and duration than they have) and it does not make 550 hp.
I think about 500 to 520 is a little more realistic.
Old Nov 1, 2001 | 08:05 PM
tacoboy's Avatar
how can a dyno be optimistic, they are a machine, machines are objective...
Old Nov 1, 2001 | 08:11 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Its not that simple. A dynos vary 2 percent minimum from one to another. There are also things like vapor pressure, water/oil temps and step rate (the rate the dyno allows the motor to acclerate when the load is on it) to consider.
If these are not held to constistent standards, inflated numbers will result. And since they don't provide these, its anybodies guess how they obtained the results.
[This message has been edited by jcb999 (edited November 01, 2001).]
Old Nov 1, 2001 | 08:37 PM
tacoboy's Avatar
2% isnt 50 horses, but besides which, if those are the numbers they got, then they are not optimistic for that combo, they are clearly possible, just so you know i didnt even look at the results, im just going on assumption that those are the numbers they got.
Old Nov 1, 2001 | 08:45 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
<font face="Verdana, Arial" size="2">Originally posted by tacoboy:
2% isnt 50 horses, but besides which, if those are the numbers they got, then they are not optimistic for that combo, they are clearly possible, just so you know i didnt even look at the results, im just going on assumption that those are the numbers they got.</font>
Lets see, if i can make a 4cyl pinto motor get 400 hp by some dyno factoring you think that is legit?
ok.. if you say so.
PS, desktop dyno says 498 hp with open headers.
Old Nov 1, 2001 | 09:59 PM
tacoboy's Avatar
it has probably been done, but if you think AFR is practicing false advertisement why dont you just report them to better buisness beaureau or something? maybe i have too much faith in honesty...
Old Nov 1, 2001 | 10:54 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
"Ceralli Competition Engines" is located in Paterson , NJ.I do not think he has a web site up right now.This guy is out of his tree,he quoted me $5,000 to assemble and dyno my motor last year.This was with all top quality parts.I built it myself,and had it dynoed at a different shop for $1,000,that is machining the block,balancing,blueprinting,and all that...and to dyno the motor.Dont even bother with these guys,nuts!
1982 Z28:355,4 Speed,Lots of bolt ons
Old Nov 1, 2001 | 11:07 PM
gruveb's Avatar
Car: 1989 IROC-1
Well, I was just curious. Very interesting. Who is producing those types of numbers out of a streetable 400?
What heads?
Old Nov 1, 2001 | 11:18 PM
BadSS's Avatar
I have NO reason to doubt if it's a fully ported intake, massaged 750 carb, they dyno tested and tuned for optimal cam timing, ignition timing, and carb adjustments,, that it could make 550 in the cell with "uncapped" 1 3/4" dyno headers. That engine with a box stock Victor JR, box stock 750, cam installed per spec card, with headers what fit inside an engine compartment (even uncapped),,, probably wouldn't make 500 horses. It's all in how much they want you to know,, or don't want you to know.
Old Nov 2, 2001 | 02:42 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by BadSS:
I have NO reason to doubt if it's a fully ported intake, massaged 750 carb, they dyno tested and tuned for optimal cam timing, ignition timing, and carb adjustments,, that it could make 550 in the cell with "uncapped" 1 3/4" dyno headers. That engine with a box stock Victor JR, box stock 750, cam installed per spec card, with headers what fit inside an engine compartment (even uncapped),,, probably wouldn't make 500 horses. It's all in how much they want you to know,, or don't want you to know.</font>
Too true....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 2, 2001 | 06:33 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
There is a rule of thumb, 1 cfm of intake flow will support 2 hp. So, a head that really flows 280, can support 560 hp. But, you can't do it with pump gas, a hydroller cam and 10 to 1 compression.
These guys have a little more experience with building HP using many combinations (not just AFR ones)
http://www.amerspeed.com/
I think too much is made of HP numbers on street engines. Build the engine for max torque over the widest range and let HP fall where ever.
If you do that, you won't worry about a few HP. Your biggest problem will be getting it to hookup.
[This message has been edited by jcb999 (edited November 02, 2001).]
Old Oct 8, 2007 | 09:23 AM
sradams21's Avatar
Car: 1991 firebird
Axle/Gears: 10-bolt 3.08
Re: Air Flow Research---Experiences?
AFR is making 540hp with a 9.5:comp 383 pump gas. With a hydraulic roller XE288HR 236/242 and their new Eliminator 195's all below 6,500rpm. JCB999 every component in the engine has to work with the other parts to make great power. Just throwing a bigger cam at it isn't always gonna help. IMO Brodix Track-I's aren't that great if your gonna spend money on brodix you might aswell save up for the SPX-18* top end kit.
Old Oct 8, 2007 | 02:31 PM
EvilCartman's Avatar
Car: '82 Z28
Dang, talk about bringing one from the dead. All the way from 2001!
Old Oct 8, 2007 | 09:30 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
knew i should have looked at the date before reading the whole thread
Old Oct 8, 2007 | 11:19 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Sep 10, 2015 07:31 AM
scotrans am
Sep 5, 2015 04:26 AM
