Wire order on the cap for a 3.1 or 2.8 v-6
Old Nov 1, 2001 | 02:25 PM
jm91rs's Avatar
I know a guy who bought a car without the plug wires on it. I need to know what the order is around the cap for this 1990 v6 rs. Thanks
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
4th gen seats, SS Chrome wheels, check out my ride at www.racecamaro.cz28.com or check out the reader's rides at: https://www.thirdgen.org/rides/index...ew&rideid=1217
Old Nov 1, 2001 | 07:54 PM
jm91rs's Avatar
someone has to know
Jeremy
Old Nov 1, 2001 | 08:43 PM
AlexJH's Avatar
Engine: 5.7L V8
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Welp, the firing order is 123456 but that's not your biggest problem. With the wires off, you need to know which terminal is #1 so you can put the wires back where they belong.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-*Slowly* collecting parts for T5 swap
Old Nov 2, 2001 | 01:54 PM
jm91rs's Avatar
Right, not firing order, the order of the wires on the cap. The wire at about the 6:30 position goes to what? 8:00 to what? and so on....
Jeremy
Old Nov 2, 2001 | 05:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What Dan told you was correct, firing order = "order of wires on the cap". The wires go on the cap "1 2 3 4 5 6", in a clockwise direction. BUT: You need to find which terminal is #1! After you find #1, you can plug in the rest.
You need to find out which terminal is #1. That can be different on every car! I have a message on how to determine which cap terminal is #1 here: https://www.thirdgen.org/messgboard/...ML/000866.html You might also want to read this: https://www.thirdgen.org/messgboard/...ML/001122.html
Good luck! Let us know how it goes.
-Tom P (Hot rodded 1986 Firebird 2.8l)
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
BBSDesigns
Aug 11, 2015 07:39 PM
