301 pontiac engine
Old Oct 30, 2001 | 05:04 PM
Duke901's Avatar
Car: 89 Formula
301 pontiac engine
What are your guys opinion on the old 301 Pontiac made in the 70's. isn't it almost the same as the old 302 chevy had and would the 301 handle power or at that be worth trying to build up. Would the engine beable to bolt right up into a firebird with the 700r4.
Old Oct 30, 2001 | 05:59 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
aside from the same bore and stroke, they are nothing alike. the 301 isn't even worth building up in turbo version. and no, it won't just bolt up to a 700r4 from a firebird.
Old Oct 30, 2001 | 06:05 PM
wataru's Avatar
Yeah from what i understand the 301 is crap. You should probably stay away from it.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
Old Oct 30, 2001 | 06:18 PM
Duke901's Avatar
Car: 89 Formula
Well, I want to do something that u dont see a lot of people doing like I want to stay away from the 305 and 350, I want something that is kinda unique so what would be the best type of engine to use that u don't see a lot of people using but that will be a good engine to have.
Old Oct 30, 2001 | 06:32 PM
SoCo80p's Avatar
i have one i just pulled out of my 80' formula, its really not all that bad of an engine, it was no 400, but for its time pretty good, with a 4.000 bore and 3.000 stroke was pretty good, i put a mild comp cam in mine and it really wasnt all that bad, and got great milage, i still have this complete turn-key engine for sale in illinois if you want it.
Old Oct 30, 2001 | 06:34 PM
SoCo80p's Avatar
the only downside is you cant get an aftermarket intake for the 301, the best was the 301 HO t/a engine with a factory single plain intake and 1" carb spacer (the one i have)
Old Oct 30, 2001 | 06:54 PM
Nitroburn's Avatar
Being different is great, but a word of warning on the Pontiac 301 engine.. it will cost you a lot of bucks. Pontiac motors are one of the most costly engines to build up and the 301 is not like the 326-455 blocks. They look almost identical, but the head deck height is about 1/2" lower, thus you can't even use an aftermarket intake from a 350 block..it won't fit! The 301 block is just casted from the 265 CID Pontiac block, just a bigger bore and longer stroke.
Trust me, I had a 265 that I was gonna build up... I changed my mind real quick when I saw that there is NOT a lot of products out there for it, and if you do find them, they are big bucks!!
Good luck though, I like the "being differnt" attitude!!!!
89 T-Top Firebird 305 TBI Project Car with approval from my wife!
Old Oct 30, 2001 | 06:59 PM
SoCo80p's Avatar
pontiac engines are probley the #3 cheapest and most common engine to build (outside the chevy and ford) they are not junk by any means and i've build a few, the deck hight is a little lower, givin the unuse of an aftermarket intake, but the HO intakes really wernt all that bad, actuallt the 301 came out first, (2bbl in the birds and big cars, the t/a's and formulas could get the 301 HO 4bbl or the 301 turbo) the 265 pontiac is really a poor platform and was used on 80-82 boats and was a POS, the 301 will use regualr pontiac roller rockers, valve covers, cams, headers, distrubtors, basically everything except the intake, really its not all that bad on an engine and forsure a unique engine in a 3rd gen!
Old Oct 30, 2001 | 07:39 PM
Duke901's Avatar
Car: 89 Formula
Well sense that might be a lot more then i expected would it just be better to put a better cam in the 305 or what do u guys suggest that i should do.
Old Oct 30, 2001 | 11:58 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Build a Pontiac 455
Go big, or go home!....
Old Oct 31, 2001 | 01:57 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, I DO know that Car Craft chose the 301 Pontiac engine as one of the top 10 worse engines in automotive history.
- Might wanna try one of the old early 80's 350 diesel engines if ya wanna be really unique.
Seriously though, if I were to use that engine, (and I most likely wouldn't) I personally, would give it a warm-over (valve job, etc..), and drive it till it dies.
So far as "building" the engine goes, it would be a waste of money IMHO. I suggest you decide what you really want at this stage so far as performance goes, and stick with it.
Daily Driver?? - I recommend a 350
Weekend Warrior?? - No replacement for displacement!! (383, 400, 454, 455?)
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit. Now for paint, interior, etc...etc.... Also:
2000 S10 4.3L 4WD LS
1995 Ford Thunderchicken, 4.6 V-8
Old Oct 31, 2001 | 02:00 PM
Duke901's Avatar
Car: 89 Formula
OK well what is the difference between the Chevy big block and the Pontiac big block like the 400, and the 455, and would the 400 and the 455 bolt up to a 700r4 and would the block fit in the car. If that don't work then what about a chevy 302 I would really like to do that one.
Old Oct 31, 2001 | 03:47 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
something dfferent?go to a junk yard and find a caprice taxi cab enngine(4.3L model)take that crank stick it in a 4bolt production 350 block with 6in. rods=presto 302cu.in.aside from numbers the pontiacs are totally different.chevy used small block and big block engines,were as the 326-455 pontiacs are identical only the bore and stroke changed.i would say stick to chevy they'll bolt in with no problem and you wont have the tranny bolt pattern problem......
Old Oct 31, 2001 | 05:14 PM
Duke901's Avatar
Car: 89 Formula
Ok I will stay with Chevy and do the 302 but will that bolt up to the 700r4 without any problems. or do I have to change something.
P.S Just curious but I could put in a Pontiac 400 or 455 without any problem. or would I have to change the tranny to a turbo 350
Old Oct 31, 2001 | 06:16 PM
Duke901's Avatar
Car: 89 Formula
Do any of you know where to get a 302 crate motor or how would u go and make one like using a 350 block with a different crank.
( What type of crank to use if it can be done)
Old Oct 31, 2001 | 06:28 PM
9.0L Firebird's Avatar
302s came about by combining a small journal 327 block with a 283 crank. (no magic parts here and crate versions disappeared 25 years ago) the ONLY reason these motors (DZ code) were made in this configuration was a 305 cubic inch limit in early trans am racing. If you want to build something unique how about a huge small block? 421, 434 or 468 cubic inches. Ex NASCAR parts are getting cheaper every year.
BBC powered 82 firebird.
Street driven (barely) Best ET no nitrous: 9.42 @142mph , Fogger installed, shooting for low 8s this year
Old Oct 31, 2001 | 07:44 PM
zippy's Avatar
Engine: 5.3L
the cheapest way to make a 302 out of newer blocks is to use a crank and rods from a L99 engine and pistons of your choice for a 350.
Old Oct 31, 2001 | 07:45 PM
Duke901's Avatar
Car: 89 Formula
Where can I get a hold of a new 283 crank and a 327 block with all the the parts to build the bottom end. I already now where I can buy the original cam and will dart iron eagle heads work.
Old Oct 31, 2001 | 08:00 PM
F-BIRD'88's Avatar
The Pontiac 455 can be bolted up to the TH700r4, with an adapter plate.
But why? This motor won't need a steep
rear end gear.It's got gobs of torque.
Just gear it for a reasonable cruise speed and
use the tried and true TH400 (BOP). You could even go with a "switch pitch" TH400.
'65 to 6'67's had 'em
[This message has been edited by F-BIRD'88 (edited October 31, 2001).]
Old Oct 31, 2001 | 09:29 PM
SoCo80p's Avatar
why would you want a 302? there powerband starts at like 4,000 RPm's you'd have to be drving around with a 3,500 stall and 4.88 gears! a 400 and 455 pontiac will fit, and they do make kits, also will fit with the TCI adapter plate, would make a great choice as you can get 400's pretty easy, 455's are a little harded, but you can use most all the stock parts in the engine and still make lots of power, plus all the low end torque will let you keep stock gears and stall and still haul *** and have daily drivin reliability, i vote go 400-455 pontiac.
Old Nov 1, 2001 | 06:30 AM
agawam's Avatar
301 pontiac was first built in 1969 as the engine for the trans am but the project was killed when it put out more hp and tq than the chevy 302 and pontiac substituted the 400 in the T/A,GM policy back then was chevrolet had to be king on the track. As for 4bbl intakes I had a 77 firebird with a 301 and the duo-jet the first duo-jets were like 50lbs the front section was the std Q jet primrary but the rear was solid so it looked like a Q jet when I removed it I found a4bbl intake so I put a std Q jet on and the engine came to life, quite impressive for no other mods done.Also the 76/77 301s were not thinwall castings and the cranks were cast iron not nodular, so if you have to do a 301 76/77 are the ones to do
Old Nov 1, 2001 | 06:50 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I have had two cars with 301 engines in them. One was a 1980 T/A without the turbo. I will tell you one thing, they weren't any real powerhouse motors, but they were very reliable,smooth running motors. and I got lots of mileage out of them with minimal problems.(Way over 100,000 on one of them)
later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Nov 1, 2001 | 03:02 PM
86SCBNJ's Avatar
301's were not a race engine in the 60's/70's. It was 303's, but the displacement ban was lifted, so the project was killed off. 301's were not around till '77-'78. They were offered first in big cars like bonivilles. In '78/'79 u could get a 4 speed and 301 in the Grand Am and Grand Prix!!! These were not fast cars, but probably a lot faster than other sedans of the time. A mild 301 can be built, but why??
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. ZZ intake, Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Suspension Techniques Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with BFG G-Force KDW 245's. Nothing easy can be fun...
Old Nov 1, 2001 | 03:40 PM
SoCo80p's Avatar
right the late 60's engine was the 303 Ram Air V, really its reversed, the pontiac allways had a little power edge over the camaros, also like 86' says the 301 was first used in 77' in base birds and big cars, then the HO 4bbl was broug out in 79'-81 on the formulas and trans am's with the optional turbo 301.
Old Nov 2, 2001 | 07:46 AM
82camaro's Avatar
Car: 82 camaro SC
Wow, I can't believe so many posted about a POS pontiac 301. My vote is for a 400 pontiac.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 3, 2001 | 12:35 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
My first car was an 81 Tubo T/A
trust me even with the turbo it
was NOT a power house.Find something
else.
Old Nov 3, 2001 | 01:08 AM
SoCo80p's Avatar
the turbo T/a was really not a bad car, it made 245 HP and 310 ft lbs of torque, for in 81' this was the baddest SOB around, thats alot of power, but givin it was in a 3.08 geared nearly 4,000 lb. t/a really kept it down, now givin in the nearly 1,000 lb. lighter 3rd gen, that would be one hell of a screamer
Old Aug 24, 2024 | 11:38 PM
GMWheesls's Avatar
Re: 301 pontiac engine
I owned a 1979 Firebird Fomula gold color with a brown Firebird emblem. It offered plenty of power, decent gas mileage and the motor was practically indestructible. It literally burned no oil whatsoever. It was smooth and powerful for a small V-8. I did have a problem with the Transmission so I swapper the OEM tranny for a Buick Transmission. The car ran forever. For a sportscar it was comfortable and it handled like a BMW. The problem I did have was people kept trying to steal it. The Steering wheel locked so that kept it in my possession.
Old Aug 25, 2024 | 12:41 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
23 years later...
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
