Oil Filter Relocation Thingy
Old Nov 3, 2001 | 09:15 AM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
My 89 Blazer winter car (4.3L) has this oil relocation deal that puts the filter up by the front left headlight.
1. What is this for? Other than making oil/filter changes easier.
2. Would this fit on my LG4?
Ludicrous Speed GO!!!
Speed Trap Exchange
Old Nov 3, 2001 | 10:31 AM
82camaro's Avatar
Car: 82 camaro SC
Only the 4wd ones got them. For example, my 91 Jimmy 2wd 4dr is located in the normal spot. Maybe the 4wd stuff gets in the way of the filter? Sure you can get a Filter relocation kit for pretty much any car. Look in Summit or Jegs. I figure if I have to get under the car to drain the oil, removing the filter while I'm down there isn't that big of a deal.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 3, 2001 | 11:23 AM
ede's Avatar
ede
besides adding a little more oil capacity it'll get rid of heat in the oil better. you can buy a single or duel remote filter from permacool. check out the jegs catalog or call 800-345-4545. cost is around or under 50 dollars.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
luvofjah
Sep 10, 2015 10:41 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
