Help!!! not thirdgen realated
Old Nov 3, 2001 | 02:06 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
my roomate has a 77 GMC 1/2 ton pickup, with a 350 eldelbrok carb, t350 tranny, today it started smoking out of the breather?? what could be causing this, and is it dangerous to the engine.
also, just this week he had new valve cover gaskets installed by a shop, could they have done something wrong that would be cuasing this?
any info would be helpful , thanks in advance
Dewey 3:16
90 RS 305 TBI LO3
36mm/24mm swaybars, Spohn Panhard, SFC, LCA's, and RLB. "Wonder"bar, Edelbrock STB, and K&N.
[This message has been edited by Dewey316 (edited November 03, 2001).]
Old Nov 3, 2001 | 02:25 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Tell him to try a new PCV. They are only a few bucks and that is generally the problem.
Old Nov 3, 2001 | 02:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
he put in a new pvc elbow and hose on the valve cover about a month ago? are you talking about that, or something more?
Old Nov 3, 2001 | 04:42 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What kind of "smoke"???
A lot of steam out of the vent cap on the valve cover could be water in the oil. (headgasket, intake gasket, crack in casting)
oily smoke could be blowby. (rings)
Change the oil and filter and see if that helps. If it helps, then returns later you know where to look. Minor water seepage can sometimes be sealed up with a engine block-cooling system sealer.
Old Nov 3, 2001 | 01:38 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Well it is defenently oil smoke, and i went and looked at it this morning, there is ALOT of smoke. we will probably try chainging oil and filter, but by the amount of smoke, i am thinking there is something more than that wrong.
thanks for the help guys, any other ideas would be great.
Old Nov 3, 2001 | 03:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Valve covers leaking oil on to the manifolds (maybe)
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
