Will Edelbrock TES headers 1 5/8" work for a 350?
Old Nov 1, 2001 | 01:43 AM
nesluopetan's Avatar
I am in the process of dropping a 350 motor into my car, I bought the edelbock tes headers for my 305 last year and had them HPC coated which cost me alot.. will these headers work okay on my new engine? i dont want to see these go since I spent so much on them, what you guys think? also if you could read my question under the TBI board, I really need help on that one.. thanks guys.. any input is great
Nate
AIM: NESLUOPETAN
Old Nov 1, 2001 | 01:55 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
In my opinion they will be fine. I'm in the same situation as you and that's what I'm using on my 350.
91 Z28
Come see The Vicious...
Old Nov 1, 2001 | 08:20 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Got them on mine.
Old Nov 1, 2001 | 09:37 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
How much power do you plan on making? 400 hp or less? I'd say the edelbrocks aren't taking more than ~5-10 hp("conservative" probably more like less than 5hp) at your power level vs. a 1 3/4" shortie header. Did you cut/grind out the AIR tubes where they enter into the primaries by any chance? I'd recommend that (it's easy ~1 hr work)and believe there is a difference to be found.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 1, 2001 | 08:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, they'll work "ok".
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 1, 2001 | 09:42 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
mine work "ok"
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 2, 2001 | 03:03 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yeah, they will work. But if you want to make big power at some point in the future, spend the extra $$$ on the SLP 1 3/4" shorties - OR, if you have a lot of money, go with the Hooker Super Competition 1 3/4" full length headers and the Mufflex Y-pipe... If you go with that setup, you will never have to upgrade your headers.... You will have to find a way to get a cat on the Hooker full length setup, or dodge the emissions testing if you have to get tested where you live.....
As for prices; I think the Edelbrock TES goes for around $400 coated, the SLP 1 3/4"s for $480 uncoated (stainless steel), and the Hooker Super Comps with the Mufflex Y-pipe will run you $880 for coated headers and aluminized Y-pipe. If you are going to get regular steel headers, get them coated.... you will not regret it......
Keep in mind that the TES actually has primaries that are closer to 1 1/2".........
I am running the TES on my 355. I am having decent results but I ported them out a bit where they meet the heads to somewhat match the exhaust ports on my Trick Flow heads. I also removed and ground out the A.I.R. tubes and welded the holes shut. I do plan on upgrading to the Hooker Super Competition full length headers this spring......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 3, 2001 | 09:33 PM
84TransAm's Avatar
They also work "OK" on my car. I originally planned on putting them on the LG4 but ended up using them on the 350 anyway.
1984 Trans Am, Goodwrench 350, TES Headers, Performer RPM Intake, Flowmaster 80 Series, Holley 600 cfm & vacuum advance, and T5 with short shift
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
djmarch
Aug 11, 2015 10:22 AM
