Who knows about Trick Flow heads?
Old Sep 24, 2005 | 11:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm looking at a set that are suppose to be 180cc intake, 63 cc chambers, 2.02/1.60 valves.
Supposed to be pre '04.
I can't find refernce to any 180cc intake runner TF heads. They're supposed to be perimeter valve cover heads with an exhaust cross over.
Are these the "old-old" design that ate valve guides? Or something discontinued in favor of 195cc intake runners?
F-Bird, you out there?
Old Sep 25, 2005 | 01:02 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Looks like Summit still sells them, so they aren't out of production or anything...
Old Sep 25, 2005 | 09:28 AM
brutalform's Avatar
TFS Twisted Wedge were the first ones that did have a guide problem. (ask me how I know this) They did have a runner volume of 185. The chamber and valve sizes are 63, and 2.02/1.60. TFS-31400001, is the part #.
If you can get them for a good price, get them, and get the guides replaced, with bronze guides, as I had done. The heads worked fantastic after that. I used them on my old 357, with a ZZ-9 cam. Car had a MPH of 107.
Also TFS are equipped with shorter length valves than other heads. You cant just go and get a Manley valve if you need a replacement. You have to get a TFS valve from Summit.
Old Sep 25, 2005 | 09:36 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
when I was looking for heads I found that TF Twisted wedge had a early style and a later style and then stopped all togeather and they only offer the trickflow heads (to twisted wedge)
the first ones would eat guides very quickly (almost right away!) this was with everything setup right
second ones were better but, as you stated they needed better parts and seemed to be ok at least much better than the first style however since they seemd like nothing but trouble they are no longer made well for the sbc that is
I found most of this info by just doing a search on this board so I guess I would only take half of that as fact
Old Sep 25, 2005 | 09:45 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Thanks Guys,
Funny, I couldn't find anything on Summit's site about 180cc TFS heads.
The P/N that Brutalform listed is what the seller posted as well, that p/n doesn't come up on Summit or Trickflow site.
Seems like after adding new parts and taking them to the shop has to be considered.
Thanks again.
Old Sep 25, 2005 | 09:54 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Summit just came out with these 180CC's Heads with smaller valves in favor of using these heads on 305's and 350's. Go to www.trickflow.com to find out more.
Old Sep 25, 2005 | 09:56 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
My bad. The new ones are 175cc. I dunno what hes talking about then. The 175's also have perimiter bolt holes and X over.
Old Sep 25, 2005 | 09:59 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I dunno, I must be "search-impaired" or something, I can't find a 180 or 185cc runner TFS head on Summit either.
Old Sep 25, 2005 | 10:38 AM
brutalform's Avatar
Thanks again. [/B][/QUOTE] [B
I just so happened to have my old invoice from Summit ( approx. 8 years old), and that is the part # on it. They very well may be not avaliable any more. I remember the G2 heads coming out right after all the problems with the original ones.
Old Sep 25, 2005 | 10:52 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yea, now I rememebr all the talk about them, IIRC, some folks had good luck with havng different guides replaced, others still had problems.
Thanks for the update.
Old Sep 25, 2005 | 12:46 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
This is from the G1 twisted wedge heads
Old Jan 26, 2008 | 12:41 PM
codeysabatini's Avatar
Car: 91 RS
Re: Who knows about Trick Flow heads?
I know this thread is pretty old but I came across it when I was searching for info on these heads. I have a chance to buy a pair of the TrickFlow Twisted Wedge part number 31400001 for $500. Would it be worth it to buy these heads for that much or should I just hold out for some other heads? Gonna use them on my 400sbc. Also was looking for the valve guides just to see how much they run and I cannot find them on summit or on the trickflow websight all the have are the valve guides for the G2 heads, so I am thinking buying these would be a bad idea? let me know what you guys think, thanks.
Old Jan 27, 2008 | 05:42 AM
BadSS's Avatar
I had the old G1 heads on a 400 with a 218/228 cam, Weiand Street Ram (7525) and 850 ad. The car was brutal through the midrange, but ran out of steam fairly quick around 5500 rpm (5800 rpm shift point). Still,, it was one of my favorite daily driver combos,,, smooth idle and instant throttle response.
He may or may not have replaced the guides already. While the guides gave many folks problems, I never had any problems with the guides. I did experience the main problem with the heads,,, a number of the K-Motion springs on MY heads broke. All the G1 heads didn't come with the K-Motions (they also used Manley and Crane - without problems),,, so some have bad springs to boot. The K-Motion have a tan stripe going down the side. If the heads you're looking at have those,,,,, budget for springs. Just an FYI,,, K-motion was still having trouble with these spring up until 1999,, don't know past that as I sold my speed shop and don't use K-motion products for the engines I build.
Anyway,, the heads are what I'd consider to be one of the best if not the best street heads available for combinations going to run dish or flat-top pistons and NEVER will run a cam over 230 degree duration and .530 lift on the intake side (roughly - depends on the lobe centerline). Any larger than that and you have to buy a special piston to clear the 13-degree intake valve. So you see they are somewhat problematic and depending on what you MAY have to replace on them,,, and MIGHT be planning to do with the engine/car (now or later),, they might not be that good a deal at $500.
Old Jan 27, 2008 | 08:21 AM
Car: 91 RS
Thanks for the quick response, the guy just had them at the machine shop to be checked out and they cleaned them up and told him everything looks good so I am going to buy them and see how they turn out. Thanks again for your help.
Old Jan 27, 2008 | 03:47 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I ran those heads on my 355 for the past nearly 10 years and had no problems with the guides, just the springs that was said above. I changed out the springs for a set of Z-28 springs and could run that motor to 6300 rpm with no issues. I really like that motor combo and I am right now in the midst of a new 400 with Dart heads. A friend of mine bought my 355 complete to drop in his ride. Go for it I say..
Old Aug 20, 2022 | 10:42 AM
mookandairin's Avatar
I know this is an old as dirt thread and am not trying to step on anyones toes but I had to share.
This is for someone looking into getting a set they found somewhere online like me whom has/had really no idea what these need and is doing research.
These heads are good street heads but they need certain things to make them right.
1, flat top or dished pistons dome wont work for you.
2, special intake rockers like Crane Gold or Comp Cams Ultra Pro Magnums. if you got em great you are a step a head
3, different length pushrods ( so get a pushrod length checker and adjustable pushrod tool like ProForm which makes makes special pushrod length tool that is cheap as hell and works great it makes a job thats a real pita with motor in the car a stupid easy process and yes again I learned the hard way due to not knowing as much as I thought I did using markers on valve tips). After buying about 4 sets of pushrods from stupid mistakes in length (and from not being able to see the roller tip on valve because truck body being right where I needed to see) I discovered this tool. Before the tool I was doing it the old fashioned way with felt tip markers looking at the wear marks etc.
4 if you want to do it the way I did it you need a lot of time and a few extra hundred bucks setting these up due mostly from mistakes and the comp cams ultra pro mag rockers or Crane Golds
I may sound like a real idiot but I just wanted to post this up for someone whom thinks they found a killer deal on a set of Trick Flow heads. I mean a good cheap set of Trick Flow heads is great until you realize they are what they are. They are a great head if they are already set up for you and ready to go properly but I think you could do better with spending a little more money and looking around a little bit by calling some machine shops for heads ppl left behind for example or know some people willing to hook you up sort of thing.
Sorry for the lengthy post, I just wanted to shed some light/insight on them as I found the info through my experience trying to upgrade
OOH one more thing, if they are (G1'S) missing any of the guide plates.......forget about it unless you are a fabricator as they as not in existence or built by Trick Flow anymore. No one is reproducing them anywhere. (one of the hickups I ran into) I had an extra exhaust or intake I cant remember and had to cut and weld it back together I.E. flip one side to make a mirror image of the one missing. Ya it sucked.
Hope someone who is reading this in the future gets something out of it. I am just trying to help someone out by saving a lot of time, headaches, and/or online searching
Old Aug 24, 2022 | 12:36 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
My advise is to avoid the chev TFS Twisted Wedge heads even if offered for free..
The current TFS Super 23° sbc heads are a pretty nice head with none of the fubar issues of the Twisted Wedge heads.
They are a better head in every way.
Lots of people trying to ditch the old Twisted Wedge Sbc heads.
89lt1
Feb 2, 2011 10:59 PM
RednGold86Z
Jun 30, 2008 04:42 PM
Mkos1980
Nov 6, 2005 04:05 PM
Elliott S.
Aftermarket Product Review
Mar 3, 2005 03:45 PM
