Is there a 168T starter with straight-across bolt holes?
Old Sep 26, 2005 | 07:36 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I have an L98 block that originally had a 153T flywheel. I'm now converting it to auto and I got a free 168T flexplate. As far as I can tell my block isn't drilled for a staggered starter. Were there any starters made for 168T flexplates without the staggered mounting holes?
Attached Thumbnails Is there a 168T starter with straight-across bolt holes?-er10.jpg
Old Sep 26, 2005 | 07:40 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
you can get a gear reduction starter from summit or jegs that is set up for 153 or 168 teeth flywheel.
Old Sep 26, 2005 | 07:48 AM
Car: '87 Camaro LT
Engine: 355 L98
Yikes, they start at $146. I think I'm better off just finding a 153T flexplate.
Old Sep 26, 2005 | 07:57 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Im sure a stock auto trans starter would be 168t also...
Old Sep 26, 2005 | 08:01 AM
Your block (like all blocks since the mid-60s) has the hole you need. You can see it plain as day in your picture.
Look at the big reference hole at the starter pad. Notice the 3 bolt holes all around it. You'll use the one out at the far end of the pad, and the one that's offset from the bell housing flange by an inch or so.
Old Sep 26, 2005 | 08:06 AM
Car: '87 Camaro LT
Engine: 355 L98
D'oh, you're right. I thought that one big hole was the inside mounting hole. So if I go to the parts store, what kind of vehicle do I tell them I have to get the right starter? It's a one piece RMS if that makes any difference.
Old Sep 26, 2005 | 08:09 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Ive got a good used one for offset pattern....20.00 shipped
Old Sep 26, 2005 | 08:13 AM
Car: '87 Camaro LT
Engine: 355 L98
Sorry, I can't wait. Leaving for school this weekend and I'm trying to get the car running before then.
Old Sep 26, 2005 | 08:14 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
np, but Im only 1 day shipping from you here in Indiana.....
Old Sep 26, 2005 | 08:24 AM
Any application at all for a Turbo 350, Turbo 400, or 4-speed will get you the right one... try a 70 Chevelle SS396 with a 400
Should be Hollander # 3510 (or 3510-S if you get it with the solenoid)
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Cleotiz
Aug 22, 2015 01:54 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
