big block transplant?
Old Nov 3, 2001 | 04:19 PM
guswedy's Avatar
what do you need to swap a big block into a third gen?
[This message has been edited by guswedy (edited November 03, 2001).]
Old Nov 3, 2001 | 04:32 PM
SoCo80p's Avatar
for the most part just the frame mounts, and all the assorys off the big block (small block stuff wont swap over) also makesure the rest of the car it built to handly the big blocks extream torque
Old Nov 3, 2001 | 04:57 PM
guswedy's Avatar
whats a good tranny to handle that power?
Old Nov 3, 2001 | 07:17 PM
82camaro's Avatar
Car: 82 camaro SC
A mild big block would work with a 'good' 700r4. With alot of torque a 4L80 or th400. A completely different rear end and good subframe connectors.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 4, 2001 | 01:47 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
A friend of mine has stuck a 427 BB in his 84 camaro. Couple of the bigger problems he had...The heater box had to be reshaped. It hit the valve cover on the wider big block...Also exhaust was tricky. Theres not a lot of room for a healthy dual exhuast like the 427 likes... And I dont think he has the hood on yet.
Old Nov 5, 2001 | 10:49 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
All the info for the swap is on my page. So far, it's gone 7.76 @ 94 through the single 3 inch exhaust and 87 octane gas.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
