Open Element or Snorkle Are Cleaner?
Should I just stick with my single snorkle air cleaner assembly and buy the $35 K&N replacement element or should I buy a K&N open element air cleaner assembly? Which setup is the best?
1987 Camaro Sport Coupe 305 V8 LG4-rebuilt-All Stock.
Future Mods: Flowmaster American Thunder 3 in. Cat-back, Catco High Flow Catalytic Converter, Hooker Super Comp Shorty Headers Jet Hot coated, K&N Air Cleaner, CompCam 264H, White Paint, IROC wheels, Alpine CDM-7871 CD player, Polk Audio speakers, Grant GT Rally Steering wheel,New Fuel Pump, Ground Effects, B&M Megashifter
Car: 82 camaro SC
Probably won't gain a thing with a K&N filter in your stock air cleaner since the snorkle is the restriction. Open element air cleaner.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Thats what I was thinking also.
LOL.
I guess I will be going with a K&N open element. Thanks.
Car: 04 GTO
Transmission: M12 T56
The open element is the cheapest option and has worked quite well for many people over the years (including myself.)
The stock single snorkel air cleaner is complete junk.
The stock dual snorkel isn't such a bad piece in terms of it's inlet size. My gripe with it is it has the same ultr-low lid profile that the single snorkel piece has. If you have a dual snorkel, just look at it from the bottom wit hthe lid on, the distance between the lip and the lid is tiny. Air flows DOWN into a carb, not across it. With so little room between the carb inlet and the lid it can't be good for airflow and mixture control. There is a fix for this, instead of using the stock flat lid, score a raised lid from a G-body or truck. It should still fit under the hood and also work that much better.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
[This message has been edited by Ed Maher (edited November 02, 2001).]
Car: 1989 IROC-1
I've gone with an open element filter....if nothing else, you'll love the sound.
http://www.gruveb.com/z28
Car: 1992 pontiac firebird
Engine: 305 tbi
As usual Ed's got it right. A good dual snorkle will flow. I still like the look and sound from an open element. The depth of knowledge of the people on these boards is incredible. I had NEVER worked with a computer controlled car before this one and was afraid to do anything until reading these boards for a while. Now there's no mystery. Even if a question does come up with in a day or so you get several answers.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
'92 firebird t-tops
Yup. Good guys around here. Thanks for the comments.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I went to the junk yard and found a lid that simply covers the cleaner element, but leaves all the room around it open. Works great--no flow restriction at all. And it still brings in some cool air from the single snorkel out front, to counteract the hot underhood air.
It also makes a good basis for cowl induction, if that's the way you want to go.
Total cost? $2.10 Canadian
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
</font>
</font>
Really good idea, Ed!
You could also buy one of those new K&N lids that are a filter themselves. Then the carb could suck air straight through the top, too.
But the price is a bit much at almost $60 US. That would nail us Canucks for more than $100 in our funny money.
Car: 91 RS
I run the taller lid with a K&N 1500 filter and a 4" hose and it pulls great. I've had it to 135
I got the lid from a "cop" 350 and the 4" breather connection from an old big block breather that was sitting around.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
in case you wanted specifics, i got one of the cheap edelbrock chrome open element's along with a 14 in k&n - it's roughly the same size as the old snorkel = if i remember correctly, i got the 3 inch tall one (either that or 4) and it sits just under the hood with about an inch of extra screw for the wing nut to go on
remember to plug that air line if you do take off the snorkel - mine has fallen off many times, and it makes the ole lg4 run like crap..errr more crappy
I think my setup works pretty well, I have a homemade dual snorkel air cleaner. I made a trip to the junkyard and picked up another aircleaner like mine and cut out the snorkel, then I cut a hole in my original air cleaner and screwed on the extra snorkel. A friend of mine gave me a taller lid air cleaner off of an old monte he was junking, along with a new element. Night and day difference. THe whole thing cost me about $20.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I've got a LG4 4bbl also. How much of a sound difference is there? Do I buy just the filter and cover or is there another conversion needed for the small breather(can't think of the name of it now, damn)element that is on the side that hooks up to my single snorkle? Which model K & N do you guys reccomend?
86 Camaro Black SS Coupe, T Tops, ASCD Daytona Twin Turbo hood, Flowmaster, Custom Black Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, leather wrapped steering wheel, shifter and emergency brake, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Car: 82 camaro SC
If you want a poor man's cowl hood, just remove the seal on the back of the hood.
82camaro
82camaro
codeysabatini
Nov 10, 2015 04:07 PM
