383 cranking too long before firing..
Old Sep 27, 2005 | 11:45 PM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
just got my new 383 running....wow, what a difference from the old stock 305. The only thing that bothers me is how long this motor cranks until it fires.
I replaced everything when installing this motor. All sensors, a new mini starter, cap, rotor, plugs, wires, and all new gaskets.
I did bypass the water from going through the throttle body, As suggested by some guys on this site. It seems like the cranking problem is worse when the motor is up to temp..it fires quicker when cold.
Any suggestions would be greatly appreciated!!
Old Sep 28, 2005 | 06:37 AM
ede's Avatar
ede
i was in reading two weeks ago. is the timing right? try moving the timing around a little, starter not spinning engine fast enough?
Old Sep 28, 2005 | 07:41 AM
iroczz89's Avatar
Engine: 383 tpi
What were you in Reading for...NHRA race at Maple grove??
Timing brings up another question. I had a new prom chip burnt for my computer and set my timing at 8 degrees b.t.d. with the EST plug un plugged.
I just checked the timing to make sure it hadn't moved, which it had not, and then when i plugged the EST plug back in i was curious what the timing had changed to....it was still at 8 degrees btd??? Shouldn't it have moved a couple degrees???
Old Sep 28, 2005 | 08:07 AM
ede's Avatar
ede
yes there for the race, and yes with the EST plugged in your timing should change
Old Sep 29, 2005 | 07:38 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 383 cranking too long before firing..
Need to adjust the crank AFR in the prom.
-- Joe
Old Sep 29, 2005 | 11:04 AM
iroczz89's Avatar
Engine: 383 tpi
And how exactly do i do that???
Old Sep 29, 2005 | 12:14 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Open the bin, click on tables, Crank AFR. Increase or decrease the number. By the sounds of it, I'd say its too rich.
You can't really change motors without tuning it. Just isn't gonna happen.
-- Joe
gixxer92
Sep 1, 2015 04:32 PM
TEEZER TA
Aug 30, 2015 06:35 PM
WIzmo
Aug 30, 2015 02:30 PM
Winchester1094
Aug 18, 2015 10:23 AM
86White_T/A305
Aug 17, 2015 12:16 AM
