surging idle need help
Old Sep 28, 2005 | 11:01 AM
51F1's Avatar
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
for some reason my car idles anywhere from 1000 to 400, sometimes it even stalls out. I checked the timing and acording to the balancer timing marks my ignition is 12* advanced. When i try to turn it back to 0* it really idles bad. I'm thinking the outer ring on the balancer has slipped and is not acurrate. Also does anyone have the numbers (readings) of the sensors for the engine controls. IAC, TPS, IAT, O2, and what ever else I'm missing. Because we have a scan tool at work that gives the sensor readings but I don't know what they should be reading (good or bad) any help would be appreciated.
Old Oct 2, 2005 | 09:54 PM
Vader's Avatar
Remove, disassemble, clean, and re-lube the IAC. Clean the throttle body before you reinstall the IAC. You might want to check the PCV valve and vent system at the same time.
Old Oct 3, 2005 | 07:13 AM
51F1's Avatar
the throttle body has been completely rebuilt. What must be cleaned on the IAC? Do I just clean the pintle off and oil that? Also I tried adjusting the IAC according to the technical article and that didn't work I don't know what I did wrong. Any ideas?
Old Oct 4, 2005 | 07:35 PM
Vader's Avatar
Once again, there is no way to adjust the IAC. It is under constant and full control of the ECM. What you need to do is adjust the throttle minimum air position so that the ECM can control the idle RPM via the IAC:
Throttle Minimum Air Position
Tools needed:
1. Torx driver # T-20
2. Paper Clip
3. Small Punch
4. Tachometer
GENERAL NOTE: The engine should be at normal operating temperature before performing any adjustments. Never rely on the dash mounted instruments for diagnostics and adjustments. The oil pressure and temperature gauges and the voltmeter and tachometer just aren't calibrated accurately enough for diagnosis, but are a relative indication for monitoring the vehicle while driving.
For this adjustment, the transmission will be in DRIVE while you're under the hood. You will need to securely set the parking brake and block the drive wheels. It would also be a good idea to have an assistant hold the service brake while you perform the adjustments.
In order to successfully complete the adjustment, the IAC air passages and pintle need to be clean. The throttle plates and bores need to be clean as well. If this is not the case, you'll need to remove the air cleaner from TBI engines or the intake air bellows from TPI engines to gain access to the area to be cleaned. A spray-type carburetor cleaner works well for this. Cleaning the IAC passages on a TPI/MAF engine will set a DTC, but we'll be clearing that later. With the engine idling, direct the spray cleaner in to the IAC air passages and around the throttle plates. Shut off the engine and continue cleaning the throttle plates by opening the throttle manually. Once everything is satisfactorily cleaned, replace the air bellows on TPI engines. Many times, this alone can solve IAC/idle speed problems.
If this doesn't solve the problem, you may need to remove and clean the IAC stepper motor. If the IAC appears to be clean and functioning properly, continue with the adjustment procedure.
Idle Air Control Cleaning
You can remove the IAC and service it. Remove the electrical connector from the IAC. Unscrew the IAC unit from the throttle body.
You can gently rock the pintle back and forth and allow the spring to extend it until it comes apart in your hands. Clean everything with lint-free cloths and a mild solvent. Harsh solvents can affect the insulation of the stepper motor coils. It's generally the dirt and buildup on this worm shaft that causes sluggish IAC operation.
When the worm gear on the pintle shaft is clean and dry, apply one drop of clean light oil to the shaft and work the pintle back into the rack gears of the motor by the same rocking motion. It takes a while to get the pintle back into the worm gears, but you'll get it. It is important to get the pintle fully retracted into the housing so that the pintle is not forced against the gears when reinstalling the IAC unit in the throttle body.
While the IAC is out, clean the air passages in the throttle body. The orifice in the TB where the IAC resides is the seat that the IAC valve closes against, and it can accumulate a lot of carbon, dirt, and debris. The easy way to do this is with carburetor cleaner and a small stiff brush.
When everything is clean and dry, replace the gasket if it is damaged, apply a little anti-seize to the threads, and torque the IAC to the proper specs. (13 ft/lb for '85-'89 , 30 in/lb for 1990-on.) Proceed with setting the TPS and minimum air position.
Locate the ALDL connector under the dash panel, in the driver's foot well area. Remove the plastic trim cover (if it is still there).
Cut and form a paper clip into a "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' sockets.
Turn on the ignition, but don't start the engine. This will force the ECM into its diagnostic mode. Wait 30 seconds to allow the IAC pintle to fully extend. Under the hood, remove the electrical connector from the IAC, then turn off the ignition and remove the paper clip jumper from the ALDL. With the IAC pintle fully extended (closed) all idle air will be controlled by the position of the throttle plates. Some manuals indicate that the EST bypass connector should be disconnected for this procedure, while some make no mention of it. While timing is a factor in idle speed, the EST should only operate as a function of engine RPM, temperature, and detonation sensor inputs. To remove all doubt, disconnect the EST bypass connector if your car is so equipped. Some TBI and V-6 engines do not have this bypass connector, and therefore must be set with no regard to the EST system. The EST can be bypassed on some cars by grounding the diagnostic terminal at the ALDL and continuing with the procedure, but the fuel mixture will be skewed to the rich side, affecting idle speed as well. In any event, the minimum air position idle speed range is wide enough to allow for some variations. As always, it is best to consult your service manual for the exact procedure for your system.
Locate the Torx screw on the left side of the throttle body. It may be equipped with a protective metal cap from the factory. This was intended to discourage adjustment. If the cap is present, use a small punch to knock it out. Once the screw is accessible, start the engine and place the transmission in DRIVE. Adjust the throttle stop to obtain 400 RPM with the transmission in "DRIVE" on an automatic transmission car, 450 in neutral on a manual transmission car, rotating the Torx screw clockwise to raise speed and counter-clockwise to lower speed. Once the idle RPM is set, place the transmission in PARK and turn off the engine.
Re-connect the electrical connector onto the IAC. Start engine. Idle speed should be governed by the ECM at approximately 600-650 rpm in "DRIVE" (for unmodified cars). Idle speed in NEUTRAL or PARK is less significant, and will be higher.
Throttle Position Sensor (TPS)
Tools needed:
1. Digital Volt-Ohm-Meter (VOM)
2. Breakout jumper wires or probes (make your own)
3. AutoXray, Diacom, or similar scanner will replace the VOM and jumper wires.
Turn on ignition, but don't start the engine.
With a diagnostic scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.07 VDC.
Connect the VOM to the TPS electrical connector terminals ‘A' and ‘B'.
With a breakout jumper: Disconnect the electrical connector from the TPS. Install the breakout in-line, between the TPS and wiring harness connector. Connect the meter probes to terminals 'A' and 'B' on the connector. (‘B' is the positive connection, ‘A' the signal ground, or negative.)
With probes: If you have very slender probes on your VOM, you can back-probe the TPS connector while it is attached to the TPS. If you have made probes of large dressmakers pins or a similar item, you can back-probe the connector as well. Connect the meter probes to terminals 'A' and 'B' on the connector.
Turn on the ignition to read the TPS output voltage at the idle position. The reading should be 0.54VDC +/- 0.07VDC. The ideal is the center of the range, 0.54VDC for a stock engine. To adjust the output voltage, loosen the two Torx screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, the TPS sensor may be failing and could be a cause of stumbling and driveability problems.
After achieving the desired setting, turn off the ignition switch. Remove all jumpers or the scanner and reconnect the TPS connector as required.
Reinitializing the ECM
If you set a DTC during the procedure, the SES light should be illuminated on the dash. This ECM retains DTC data for the previous 50 engine starts, so the codes will eventually be cleared. If you want more immediate results, after shutting down the engine disconnect the negative battery terminal for five minutes. This will clear the ECM of all diagnostic trouble codes. Clearing the ECM also clears any data learned about your engine, and clears the radio presets. If you have a Delco-Loc or Theft Loc II radio, make sure you follow the procedure to unlock the radio protection before disconnecting the battery. This five minutes is also just about long enough to clean both battery cables. Reconnect the battery. When you first start the engine after clearing the ECM, the engine will operate with base parameters programmed into the ECM PROM. These parameters may not be optimum for your engine, but the ECM will enter a Block Learn Mode soon after the engine is warm and enters Closed Loop Mode. The ECM will write new data tables specific to your engine and will eventually rely on those tables instead of the base tables of the factory program. You can expedite this process by driving the car for 20 minutes under varying conditions to allow the ECM to initialize. Or you can wait and drive the car normally at your convenience. The BLM tables are constantly being updated as sensor input ranges change, but the greatest change will occur within the first twenty minutes of Closed Loop operation.
Old Oct 5, 2005 | 01:51 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
So when you adjust the screw, do you look at your own tach at how many RPM's to set it at, or what??? Should you set it to where it seems like the idle is good???
Would bad IAC cause driveability problems, at least the response from idle.
Maybe while driving too???
Thanks for putting up pics, I was wondering about few things. I just wasnt sure of all of them.
Old Oct 7, 2005 | 05:56 AM
51F1's Avatar
ok I just disassemble my IAC and cleaned it per instructions, reinstalled it and set minimum idle air with the screw on the throttle body. The problem I have now is when the engine is cold it doesn't want to stay running. It will idle for a few seconds and then stall out. While driving it seems fine, and after it warms up it idles steady at about 750, which seems good. Also on my way home last night the SES light came on, I checked it with a cheap scanner and got code 32 which according to the book is EGR. Any ideas what else is wrong?
Old Oct 7, 2005 | 03:48 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Make sure you hooked up the vacuum line going to the bottom of the throttle body and that both connections are good on the EGR solenoid. Might have pulled loos a hose or cracked one if they're old and brittle.
Old Oct 7, 2005 | 04:31 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I've been going through the same problems. I cleaned out the IAC and that helped but I'm still surging a little bit.
Where would the minimum air adjustment screw be on a TBI car?
Old Oct 10, 2005 | 09:01 AM
51F1's Avatar
On the driver's side right in front of the throttle lever on the throttle body base just below the top surface there is a little metal cap. You have to look closely because it might be full of crud. Just take a small screwdriver and punch a hole in it towards the outside edge, then just pry it out.
Old Oct 10, 2005 | 08:33 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Old Oct 27, 2005 | 02:55 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, sorry to bring this up again, but I was trying to find the air adjustment screw, and I don't see a cap or screw where you described it, but there are a few holes... Does anyone have pictures?
Old Oct 27, 2005 | 05:21 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Good question, I've also had an idel problem with my camaro and maybe someone could elaborate on a TBI specific engine on how to make the adjustments and where the items are located...
Old Oct 28, 2005 | 12:23 PM
51F1's Avatar
I will try and take some pictures this weekend and then figure out how to post them here. Stay tuned!
Old Oct 28, 2005 | 08:24 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Never mind, I found it! I was looking right at the cap the whole time and didn't even realize it
For those of you who still want to know, It's on the front of the throttle body, on the driver's side. The cap actually looks like an indentation in the throttle body (that's why I didn't see it at first). There's also a hole right above the cap. Some pictures would definitely help.
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
