plug wire help, quick!!
Old Nov 5, 2001 | 01:52 PM
cort351w's Avatar
Hey, I want to get my car running again as quickly as possible so I don't have to drive this Astro van. I have a 91 formula WS6 with a 305 tpi. The motor is stock right now, but I plan to mod it next time I have enough money. I have headers already.
What wires should I get? There are wires like the Taylor 8mm HEI wire for $22.69. Then there are middle price wires like Moroso Blue Max 8mm for $42.99. Then there are lots of wires that cost more.
I don't want to spend more than I have to, but I would rather pay more and get a quality product than buy something that sucks just because it's cheap. I don't really plan on racing, but as I said, I am going to add some power to my engine and I need my car to be very reliable.
Old Nov 5, 2001 | 05:50 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
There have been several questions about wires here lately. Doesn't seem to be any overwhelming agreement about brand or what type of boot end. (straight or 90%). I bought 8mm Accel w/straight boots, universal fit because I didin't use the factory routing. I'm sure most of thr good aftermarket brands are fine like accel, moroso etc. Some people like the bigger 8.5mm but hey wouldn't fit the looms I wanted so I got the 8mm. Good luck.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Nov 5, 2001 | 06:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
With headers you can't use straight boot, get 90*, MSD Superconductor 8.5mm seem to be the best, but I have used the Moroso and was satisfied with them. Word of advice buy wire looms and you won't burn 3 wires like I have.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 5, 2001 | 07:07 PM
breathment's Avatar
Crane Cams has a wire set out called Fire Wire. they really good, low resistance, and are only like $40 custom. look for them at carparts.com thats where i brought mine
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 5, 2001 | 08:02 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You know, the stock GM 8mm wires are very good, though I don't know if they are priced right. Knowing GM, probably not.
Old Nov 5, 2001 | 08:44 PM
rezinn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
</font>
Im using straight boots on some of my plugs, I have edelbrock ceramic coated headers and little 1500 degree insulator booties
Old Nov 5, 2001 | 08:52 PM
Car: 99 Formula
Axle/Gears: 342
Yeah you can use straight boots on a few plugs but all straight won't clear the headers all the way around. I also bought some heat protective sleeving, and wire separators, I don't want to take any chances after buying so many sets of wires.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
