Alternator replacement
Old Nov 5, 2001 | 01:03 PM
bklucas12's Avatar
Need some help, took off the serpintine belt, just a few min ago and was looking at my alternator and it has what looks like star shaped screws holding it in like you would need an allen wrench, plus there is this huge cast iron thing its bolted to and it looks as though I would have to take off like 5 pulleys to get this off cause its attached to the alternator, maybe there is a trick to get these suckers off? if any of you guys could give me detailed instructions on how to get it off It would be appreciated.
1988 Formula 350
Maroon, 5 speed
Edelbrock 750 cfm carb
Edelbrock Performer RPM intake manifold
Hooker super comp. headers
Hookerheaders 3 inch cat-back
3 inch pipe from headers all the way to the muffler
Gutted cat
K&N filter
WS6 Package
ATGI underbody purple neons
Black light interior
Old Nov 5, 2001 | 02:17 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the star screws are not allen. they are Torx. I think the one you need is about a 15.
I don't know about the cast iron. The only thing on my alternator is the cooling fan.
Old Nov 5, 2001 | 02:44 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
You will need 2 different Torx bits. Sorry, I can't remember the numbers off hand. 10mm socket, and 1/2" breaker bar or ratchet.
1.)Take the serpentine belt off using the breaker bar to loosen the idler pulley.
2.)Disconnect the battery
3.)Remove the 10mm bolt that holds the alternator wire on.
4.) Unplug the other 2 wires.
5.) Remove the 10mm bolt for the alternator to exhaust manifold bracket.
6.) Remove the 2 Torx bolts holding the alternator on.
7.) Remove the alternator. Might take some persuasion wiht a rubber mallet. To reinstall, just do everything in reverse. Pretty easy. Good luck.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Nov 6, 2001 | 02:07 PM
bklucas12's Avatar
Ok so I got a 5 set of torx bits and tried to use them on my alternator, I got one off but there is 2 more that are torqued on there so much that It seems IMPOSSIBLE for me to get them off, plus the screws are becoming stripped and I am worried that if I try and harder they will become totaly stripped.. I need help bad what should I do to get this damn old a*ss alternator out?
thanks
1988 Formula 350
Maroon, 5 speed
Gutted cat
K&N filter
WS6 Package
Old Nov 6, 2001 | 03:54 PM
IROC-KET's Avatar
Vice-Grips and a breaker bar worked for me. It wasn't pretty, but effective since one of my torx bits was also partially stripped.
dutch930
Sep 11, 2015 06:58 AM
Cleotiz
Aug 23, 2015 12:07 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
