Trouble Codes
Old Sep 30, 2005 | 08:47 PM
IrocZ51086's Avatar
Trouble Codes
DELETE THIS THREAD
Old Sep 30, 2005 | 09:01 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
For future reference, click here and scroll to the bottom of the page.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
But here are the meanings of your codes
13. Oxygen sensor signal stays lean during warm engine cruise
23. Low temperature at manifold air temperature sensor OR
Throttle position sensor error
44. Oxygen sensor lean
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
Old Sep 30, 2005 | 10:15 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
1988 5.7L IROCZ TPI
Clear codes, read, if code resets then:
13 - Oxygen Sensor voltage fixed at 0.35 -0.55vdc; open circuit condition.
23 - MAT reading below -22°F with KOEO
44 - Oxygen Sensor voltage below 0.35vdc (engine idle @ 1000rpm/coolant (167°F to 203°) lean exhaust, or signal short circuit to ground.
54 - low fuel pump voltage.
Old Oct 1, 2005 | 12:52 PM
IrocZ51086's Avatar
thanks ill try it out if not i am going to change my TPS
Old Oct 1, 2005 | 06:30 PM
RedIrocZ86's Avatar
Car: 1986 Iroc Z28
Engine: 5.0 TPI
Transmission: 700-R4
the TPS has to be at 0.60 or 0.75 calibration other wise it will show a code or numerious ones
Old Oct 1, 2005 | 06:31 PM
RedIrocZ86's Avatar
Car: 1986 Iroc Z28
Engine: 5.0 TPI
Old Oct 3, 2005 | 06:16 PM
RedIrocZ86's Avatar
Car: 1986 Iroc Z28
Engine: 5.0 TPI
maybe its the fuel injectors leaking?
Old Oct 9, 2005 | 09:18 AM
RedIrocZ86's Avatar
Car: 1986 Iroc Z28
Engine: 5.0 TPI
the engine is flooding in his camaro.... TPS?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
